I have asked this question before but it has been awhile. Is the any option out there to run on a Raspberry Pi 2 or 3 that can take audio from the SDS200 via the LAN and also send alpha tags?
If you're going to run a RPi3 (or 4) the better option is to buy a $25 RTL dongle and run an sdr radio and streaming software all on the pi. Will cost you about $35 total and be good for any P25 system.I have asked this question before but it has been awhile. Is the any option out there to run on a Raspberry Pi 2 or 3 that can take audio from the SDS200 via the LAN and also send alpha tags?
Not a simulcast system
I want to use OP25 to stream an Ohio MARCS simulcast system and free-up one of my SDS scanners. I have a few questions:
1. Is the decode of the simulcast comparable to a Uniden SDS scanner?
2. I have a Raspberry Pi 2B. Will this be sufficient?
3. Do I need two SDR sticks?
4. Can I set up a scan list and stream alpha tags as well?
5. Is there a comprehensive guide to setting these up?
Probably better but then I don't own a Uniden SDS Scanner. Op25 is excellent on Simulcast (LSM) and TDMA systems.
I would strongly recommend a RPi3B or better.
No, op25 tunes a single SDR back and forth between the CC and Voice Trunk Channel.
Yes. Boatbod's op25 fork has the capability to read a tag file and then send meta data upstream.
You would use Liquidsoap in addition to op25 on the same Pi to stream you audio and meta tags.
There should be plenty of information posted here. See also the README-RPi-3 once you download op25.
