Raspberry Pi feed host
ltginrage
Would some one be able to help me set up my feed on a raspberry PI 3Model B I'm setting up dark ice and dont know how to save the config file after editing it
ltginrage
I got passed that part. It's now not starting the feed
wgbecks
NE Wisconsin
If you're intention is to use the Raspberry Pi to stream audio then the correct application would be to use Liquidsoap that directly interfaces to op25 and most any USB soundcard if you need to use it to stream analog audio form an external source.
Let the forum know a bit more about what exactly your feed setup needs to be and we can help you get it setup and configured.
Bill
