Rdio scanner server and saving changes
Clats97
Ottawa
Hello, i set up a local rdio scanner server thats connected to sdrtrunk so i can roll the tapes back if need be. ive been editing the talkgroups and organizing everything, and have made some serious progress. however i am having an issue that just popped up out of nowhere. all of a sudden, when i make changes to a talkgroup name etc, i cannot save the changes. the save button is greyed out. also, there is a duplicate tag, but it doesnt show up in the tag section and when i looked through the TGs i couldnt find any duplicates. im relativley new to SDRs, i have a lot more experience with scanners.
any ideas? can anyone throw me a bone?
frazpo
SW Mo
The app is pretty stable but I have experienced a few hiccups. Did you try stopping Rdio and starting it back up again?
noamlivne
Where are you trying to perform the updating? In SDRTrunk or in Rdio-Scanner.
If you enable the Autopopulate option in Rdio-Scanner, you will have to perform all the updates in SDRTrunk. Rdio-Scanner will then take the identifications from SDRTrunk. So in this case SDRTrunk is "stronger" than Rdio-Scanner.
Regardless, I think, that if SDRTrunk is streaming to Rdio-Scanner and you try to make changes it can be a bit sluggish. Don't forget to press Save (and perhaps also Export the Settings).
I would think that stopping both programs and restarting them can help with greyed out icons.
Clats97
Ottawa
Yes I'm good not just trynabfigure out poet forwarding now lol I'm just using tailscale rn
