I know the ct police have rebanded. do i have to do anything? all i did was change the control channel to 853.9125 for troop c+k and iam hearing the calls. is that fine? I have the Radio shack Pro 96 Digital Scanner
Joe
Joe,
Easeist thing to do. Go to
RadioShack USB Cable, and order it. Then when the cable comes go to
Programming Cable Information and read the bottom paragraph carefully! Once you've installed uptodate drivers, go back to
PRO-96 Software - Win96 - Data Management Software for the RadioShack PRO-96 and PRO-2096 Digital Trunking Scanners and download it. Be sure to follow all instructions on the page. It's a little old fashioned the way he wants you to put it in program files and then unzip. It was originally made on win 2k.
Plug the usb end to the pc, turn scanner on, load win96, plug mono (put adapter on jack end) end in pc/if. Wait for it to say clone mode or something like that. then go to scanner>download from scanner. Youj'll see all your ch's and settings.
Now go to File>Save and save a "master" file for emergencies. Trust me. Then do file>new template, and download from scanner again.
Then go to Channels tab click on Mot3600CC, Multitable and click on extended tables button and then go under 3600CC and check 800 Rebanded. Also make any other changes like make all CSP Conventionals and Itacs 866-868 bring down to 851-853. In fact I have to do that. Do also all 821-823 inputs down to 806-808. Be sure to do the rebannding process with all banks as it might or might not only do the ones you selected. I have to do that while I still have 30 days free. Also clean up your scanner while you're in there as well.
Then save the file as "masterrebanded and then do Scanner>uploadtoscanner and you're all set.
I would not use a usbtoserial adapter on an old Pro92 serial cable. Unless you have an old working pc with win2k or higher then use the cable on that pc. You'll save that way as I did. But just easiest to buy a cable. I don't think SM will charge you shipping for CT. For future sake it's always best to keep a cable lying around.
If any info is wrong, then someone please make it right. I just used my old 92 cable to a 99 HP running win2k with no trouble. Bought a Syba usb to serial and had a heck of a time with it. Just spend the extra 20 and you'll save yourself the hassle! Hey you got the win96 free for 30 days. Is it better to spend 30-60.00 on reprogramming or 430-530 on a new radio when the 96 does the same thing?
Peace all,
shawn
