drink the kool aid and get a bct15x
200 bucks or so
200 bucks or so
They would like to put them here:
15675 Jackson - Sloughouse Road
Rancho Murieta, CA SACRAMENTO County
Nope. I programmed all 11 frequencies into my PSR-300, selected the correct trunking table and that was it. I did not need to change the TG IDs. The 7th frequency in the list was the cc today. It usually changes at midnight. I watched the voice channel for about an hour and found it interesting that all of them fit the format of 85x.xxx0 MHz; the freqs that won't track in older scanners.I must be doing something wrong I just updated my firmware on my bc246T to support rebranding. Then reprogrammed the entire database for roseville with the new frequencies back into my scanner only to find the talk group ids not working. Is anyone else having trouble with it?
so far data channels have been 853.350 and today data channel is 853.050
we will see what tomorrow is - whether they went with 2 , 3 or 4 data channels
my GUESS is just 2 with only 11 channels or so
most cdc only use 1 channel - but rotate between 2 repeaters on same freq to cycle the rptrs
Roseville, City of (Public Safety) Trunking System, Roseville, California - Scanner FrequenciesPress Release
[FONT=Tahoma,Arial,Sans-Serif]2/25/2010[/FONT][FONT=Tahoma,Arial,Sans-Serif]FOR IMMEDIATE RELEASE
[/FONT][FONT=Tahoma,Arial,Sans-Serif]PRESS RELEASE #10-3[/FONT][FONT=Tahoma,Arial,Sans-Serif]Subject :[/FONT]
[FONT=Tahoma,Arial,Sans-Serif]Can't you hear us now? Roseville Police and Fire radio frequencies rebanded[/FONT][FONT=Tahoma,Arial,Sans-Serif]Contact :[/FONT][FONT=Tahoma,Arial,Sans-Serif]Dee Dee Gunther, Police Public Information Officer (916)774-5015/257-1942
ddgunther@roseville.ca.us
[/FONT]
[FONT=Tahoma,Arial,Sans-Serif]Can't you hear us now? Those who enjoy listening to Roseville Police and Fire Department radio traffic at home may be experiencing problems with their home radio scanners. That's because the City of Roseville has rebanded its 800 MHz public safety radio frequencies. Rebanding is a federally mandated nationwide project aimed at fitting more public safety radio frequencies into a limited bandwidth, conserving and making the best use of a public resource...[/font]
hrm so they did change last night. I noticed that RPD is still working on my scanner tonight but didnt noticed they moved the data channels. Hopefully they will decide on the data channels soon![]()
Many paranoid agencies in many states would fall on their virtual swords before issuing such a press release.
The data channel will keep changing, its normally every 24 hours for Roseville. Did the same thing on the old frequencies as well.
As long as you have all the rebanded frequencies and the proper band plan programed you should be ok.
Ok everyone, I have a question: I did the update a couple days ago when avtarsingh posted it, and included the custom bandplan that he showed in the submission. Because I haven't worked on a lot of TRS's, I asked other Admins to review it for errors. I was told that I should not have included the bandplan because it looked like only a partial bandplan, and unless the system was non-standard, I shouldn't need it.
So, I went in and deleted the bandplan I had entered, and just kept the updated frequencies. Anyone who has already made the leap and is getting reception (and knows TRS systems), please let me know by PM or submission whether there needs to be a bandplan, and if so, what the complete bandplan is.
Base, offset and spacing do not apply to 800 MHz trunking in this radio. That would be used for 400 MHz UHF systems.Having trouble programming my RS PRO-164 for the Roseville rebanding. This radio is supposedly the same as a PSR-300. Put the new freqs in, but have been unable to put in the custom info, ie, the base freq, offset and spacing.
I am running v1.06 firmware. V1.07 corrects a problem with EDACS. I use WIN97. Go to the bank where you've programmed Roseville. On the upper right of the screen, select "multi-table". Click on "Extended Tables" and select "800 MHz Rebanded". Program the new data in to your scanner.I noticed that gmclam was using a PSR-300, maybe he could tell me the secret. By the way, the radio firmware has been upgraded.
