Rebanding in Sacramento or Roseville
avtarsingh
Cyberspace
try the freescan
its free and i think the best software around
and you can import systems from radio reference nothing to program just import it
benca
Orangevale, ca
Hi everyone. I have a uniden BCT15 and just today discovered the rebanding. Ive read through this thread on how to set my scanner up, but can't really make much sense of it (still a pretty novice user). I am using the ARC15PRO software, and used the online service to program the new trunk system... is that all i need to do, or are there additional steps?
Thanks!
Make sure your ARC15 is the latest version. Look in the ARC trunk system parameters for each system and choose custom bandplan or the rebanded option see image below.
Also Check the Wiki on this web site, make sure you have the latest firmware 1.06.00 for the BC15.
BCT15FirmwareUpdate < UnidenMan4 < TWiki
Then create a Motorola 800 Custom Band Plan (Rebanding)
1. In the Site setting menu, select Edit Band Plan.
2. Select the band plan entry to edit.
3. Set each of the following entries for the band plan:
* Set Base Freq (Upper and Lower)
* Set Offset
* Set Spacing
For standard rebanded systems, you need to set Band Plan 1 and Band Plan 2 as:
Band Plan Base Freq (Lower) Base Freq (Upper) Offset Polarity Spacing
1 851.0250MHz 854.0000MHz 440 + 25 kHz
2 851.0125MHz 868.9875MHz 0 + 25 kHz
325xia
Rancho Santa Fe, California
I can't get my Uniden 396xt to "hear" anything on the new reband channels. I followed the instructions here. I have to manually enter all 11 frequencies. Then I did a Custom Band Plan following the Lower and Upper Freq's. I still hear zilch.
Any suggestions. My old system with Roseville worked fine until this change. So, it's not the radio. The 396xt has everything needed to monitor this system.
Thx
325xia
Still Not Hearing Anything in 12 hours on ReBand
I Programmed the following and am still not hearing anything. I have a Uniden 396XT. Anyone else not hearing anything? What am I doing wrong?
custom rebanded mot
put in trunk freqs i put in all 11 -
851.2375
851.5750
851.7250
851.8750
852.0500
852.1250
852.3750
852.8250
853.0500
853.3500
853.5500
system band plan lower freq 851.0125 upper freq 854.0 25khz spacing offset 440
Thx,
Michael
325xia
Nevermind. It's working now. The reception is much poorer on the Rebanded system. That is the problem. I wonder why it is? Works when I'm closer to Roseville.
Sac916
following earlier conversation (this thread spread out to a couple different topics)
Right now.....
CHPD T1 is patched with Roseville PD 1 for 5150 in downtown Roseville
So this means CHPD (SRRCS) dispatch has patch capabilities with Roseville TRS
This is NOT via the Comm Link - This is a direct patch via a SRRCS dispatch console.
scannerboy02
Right now.....
I had a conversation with a CHPD dispatcher back a few weeks ago and he said they do have a stand alone Roseville PD radio in the radio room at CHPD that is on the dispatch console.
