Rechargeable External GPS Project
jonwienke
More Info Coming Soon!
VA
Having the extra reliability means getting fixes in areas where one system might not work. And having the coordinates display onscreen can be useful even if the scanner doesn't need 5 meter precision.
UPMan
In Memoriam
Arlington, TX
You can better approximate the shape of an irregular (zig zag) shaped entity by using multiple rectangles. You are not limited to a single rectangle.
nessnet
Eastside of Lake WA
UPMan, thanks - I have some entities with 4-5 rectangles already, so I am well aware....
Mostly because of one dispatch being done for non-adjacent, multiple towns/cities.
While you are certainly 100% correct, it reaches a point where it just isn't worth the effort to get that detailed. Then again, it is just a matter of time/effort.
IMO anyway...
nessnet
Eastside of Lake WA
Jon,
So.....
Do you want to swap for one of the new ones?
The above is (partially anyway) in jest. ;-)
The engineer in me does always like to go for the latest/best/most accurate.
If you remember, some time before I purchased, I was asking about Glonass capable modules.
Scanningar
Arkansas
I received my external GPS unit and BCD436 and SDS100 cables today. Auto on/off and GPS is working on my BCD436HP. On my SDS100 I am receiving a "Low USB Bus Voltage" error. If i
I press the button on the SDS cable the GPS power light will come in, but then go back off as soon as released. If I hold the button down on the cable I can get a GOS connection without the voltage error. I have also tried plugging the GPS in to wall power, and then the cable into the SDS.
I usually keep Charge While On enabled, but seem to get the voltage error whether that is set to on or off.
Am I missing something here?
Sent from my Nexus 6P using Tapatalk
jonwienke
VA
If you press the button on the SDS100 cable, it should lock in the down position to force the GPS to stay on. Try pressing it a little bit more firmly.
If the GPS is plugged into USB power, the auto-on/off will work without the button, but you need a heavy-duty USB cable for the GPS to avoid voltage errors, because the power is going through both cables.
On an unrelated note, I believe I've got the reconfiguration issues resolved, and should have my backlog of GPS orders caught up this weekend.
jonwienke
VA
Pretty much. The difference is inside the module and which satellites it uses to calculate a fix.
David628
Colorado
Got mine and its working great on the SDS 100 during my summer vacation trip! Thanks @jonwienke for a great product!
