ProScan Recording from BCT15X
N1GTL
CT
I am new to ProScan and I am looking to set it up to record audio from my BCT15X. Do I need to make cabling to go from the scanner to the computer audio card? I searched for posts and videos on YouTube that can walk me though this but I did not find any.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
As USB is not set up for recording audio, I would think a separate cable would be necessary.....Mike
ProScan
Software Provider
Ontario, Calif.
You need a standard 3.5mm stereo cable connected from the scanner to the computer sound input device.
If using the REC jack then the database needs the system Record option set to All Channels or Marked Channels. If Marked Channels then the channel Record option needs to be set.
