SDS150: Recording function
Ubbe
Stockholm, Sweden
the latter is stereo only and I want the scanner audio separate, without being mixed.
Yes, but I was thinking that you perhaps didn't need a stereotrack to be recorded with the video, then one channel used for video and the other for the scanner audio and as it is a digital recording there's no crosstalk between channels. There's usually a way to split the mic cable to only use one channel and the other plugs into the scanner.
If you have a scanner that use WiFi or Bluetooth then that can also stream audio and then a mobile phone can use a suitable kind of app that has a recording function that can be set to do constant record of that source to its memory card.
/Ubbe
hiegtx
Dallas, TX
Thank you for this info. It seems in the screenshot in your later post, the app recordings are also squelch activated seeing that they are only a few seconds in length. But please do enlighten if there is a way to record true continuous recording int he app (including the silences) in a single file.
The 'separate files' generated via recording contain the basic statistics of each transmission- frequency, talkgroup (if from a trunked system). and the channel details (system & department if the channel (or TGID) was programmed. While I see your point about wanting a continuous recording, with gaps of silence to sync up with a video, there's no current Uniden scanner that will do that. It's not an option with the Whistler scanners either, as far as I know.
