The issue of how the Alpha Tag and Description should be 'linked' was discussed in some other thread. The concern is what is the expectation for how the information will be presented to the user. Prior to the HP-1, the assumption must have been made that scanners would display the Alpha Tag or maybe the Alpha Tag and the frequency. I've seen some Alpha Tags use frequency to disambiguate between several similar entries.
Anyway, here comes the HP-1. It doesn't display the Alpha Tag. It displays the description. Here is an example of a page that really shows the issue. Someone keys up on CLEMARS 20, and all the HP-1 user sees is 'Northern CA Use Only', and that isn't very useful because that is the same tag as CLEMARS 21.
The question is does the Description tell something 'about' the frequency? Or does it have to define the frequency? Because technically, if it is just 'about' the frequency, then 'Northern CA Use Only' is a valid, but useless tag.
I'd like some 'official policy' so we can get a resolution between RR.com staff/policy and how Uniden is going to actually present the data as it is displayed on the HP-1. I see these possible resolutions:
1. RR.com does nothing to clarify policy.
2. RR.com defines 'Description' as an 'adjective' field that describes something about a frequency instead of a 'noun' field that names the frequency.
3. RR.com defines 'Description' as a combined 'noun'/'adjective' field that labels the entry as well as providing more information about usage.
4. RR.com defines a 'Notes' or 'Usage' field for things like 'Northern CA Use Only'. Alpha Tag is used for scanners that support only a 12 character limit. And Description is used for a more meaningful/readable tag.
5. ...
Because once we define the real intent of the field, we can go back to Uniden/UPman and say, that the db usage is wrong and the HP-1 needs to display Alpha Tag *and* Description in order to identify a frequency. Or we end up making a ton of submission requests so that 'Description' fields actually provide useful information for folks who are using/going to be using the HP-1...
5. ...
