Request a little help from Trenton area radioheads.
rrbum
Been watching 463.2875 Mhz for a bit and noticed a morse code identifyer from a local communications outfit. I am curious if this system is still operational. If anyone can copy the ID which rolls around every hour or so, please report. I am wondering if this system is in use or not. Thank you.
Whiskey3JMC
Airwave surfer...Cowabunga!
Philly burbs 🇺🇸
I usually gather recordings and run them through Audacity so I can replay & get a visual on the waveform if the signal is strong enough. Helps tremendously to know at the minimum what morse digits sound & look like. Highly unlikely you'll have more than one station within range with the same 3 trailing digits (862 for the station in question?) so...utilize your FCC lookup tool of choice to research what you heard/saw and you'll get your answer. Include expired & terminated licenses if necessary.
rrbum
I have decoded the morse. That is how I knew it was the telephone # of a communications outfit in Trenton. I am asking for a little help in identifying what type of activity (if any) is on 463.2875 and if it is analog or digital etc.
ecps92
Taxachusetts
Telephone # or Call Sign ?
Please share...
IF it belongs to a Radio Shop they likely lease out (guessing without seeing the license) to local business users
dave3825
Suffolk County NY
Maybe post what you have? Any numbers decoded?
There is a license for a trunked system that may or may not be in use, and is not in the database. County of Mercer, seems like county parks use.
rrbum
Appreciate the replies. I can barely receive, but every so often 6093940001 is broadcast. It is the telephone number for MPS Communications, 1420 S. Broad St. Trenton, NJ.
ecps92
Taxachusetts
sounds like
a. someone got a used controller and did not reprogram it
b. current controller not programmed correctly as it is generally the FCC Callsign not a phone #
Don't see in NJ or PA a license for that company, unless I missed it.
Even checked expired licenses.
Anyone know if MPS ran under a prior name ???
Thanks to Dave, for the list and Yup, not licensed under MPS for that Frequency
rrbum
sounds like
Interesting, thanks. I figured there must be someone out there who can receive this freq well, and thought I'd ask if they would give it a listen... You know...
