Did you try Mouser for parts/cables and such? Mouser Electronics - Electronic Component Distributor
Monster awesome impressive.
Seriously... good work,
One question though. While I do not really understand how a GPS improves or helps scanning, I have been playing with one and have successfully connected a GPS to my 396XT. Does your set up give me that option?
W4DOJ
Hi,
First let me say,,, How do I get a set? I want one as well. This looks like the answer I have been looking for. Great idea!!!
Thanks! I wish I could get this thread stickie'd![]()
Your wish has come true :lol:
By the way Jason, super job on this project!
CG -- I stand corrected. Yes, that is the case. You can only use a BCD396XT with one external accessory, either the RH-96 or a GPS unit with it but not both at the same time.
This is due to the fact that the BCD396XT only has one serial port and when connecting it to the RH-96, you end up using that port up.
This has probably been asked before, but what are the dimensions of the boards? I know that you aren't going to provide enclosures do to cost factors, but I'm trying to get an idea of what I need in regards to a case.
I might have answered this before, but the answer would not be valid anymore. So it's good that you asked
The head-end board was slimmed down so the size changed:
Head-End (L x W): 42mm x 38mm
Scanner-End (L x W): 50mm x 42mm
If you don't care about seeing the LED on the head-end, you could use some large heat shrink wrap to cover the board OR use the clear stuff and you can still see the LED![]()
