XPR RMN5050A
kenneykirk
Springfield, IL
I have a Motorola desk mic connected to an XPR 4550. Everything works however my personal preference is to press down on the PTT button. The mic I have requires you to push in on the lighting bolt. Can this behavior be modified?
KG4INW
Midlothian, VA
I'm not quite sure I follow, as the lightning bolt labeled side is the default PTT button. Unless if you're referring to the monitor labeled side (speaker symbol). You can remove the bottom plate of the mic and flip a DIP switch to make either button work as PTT. See here (Model # is different but the information still applies): Desk Mic RMN 5083A SETTINGS
kenneykirk
Springfield, IL
This mic requires me to press in on the top of the PTT with the lightning bolt to key up. I would like to press down on the opposite end of the PTT to key up.
K2NEC
5F6
You should be able to just press down on it. It's a rocker switch. If you can't check for any debris that might be under the switch preventing it from being pressed down
KG4INW
Midlothian, VA
I see now. It's either dirty as suggested or the switch itself has failed. Motorola considers the whole microphone non-serviceable but see if you can take the bottom plate off and try to clean it carefully.
kenneykirk
Springfield, IL
Thanks everyone for your advice. The problem is the contact pad underneath the bottom PTT button is inoperative. I set the dip switches so that the monitor button is also PTT and called it a day.
