Rpm2 system scan
hou30guy
Spring tx
Hi, in system scan is it supposed to be proscan or wide area scan for nas. Im on txwarn system in harris county tx
hou30guy
Spring tx
KC8ONR
bridgeport
Scan Type
This control enables or disables the multiple systems scanning and to select the type of multiple system scanning for this personality.
When Disabled is selected, multiple system scanning is disabled and the radio will not be able to scan out to other systems in the personality.
When ProScan is selected, the radio uses the ProScan algorithm for multiple system scanning. ProScan is a wide area system scan algorithm designed to select a new system to communicate on when the selected system drops below a predefined level. The algorithm used by the radio will depend on both the radio platform and the radio code.
When Wide Area is selected, the radio uses the Wide Area System Scan feature. If the radio loses the control channel of the selected system, the radio will start scanning (searching) for a control channel from the systems in the wide area scan list.
wa8pyr
Lead Database Admin
Ohio
And to clarify, when Harris says "System" they generally mean a "System" in the radio programming. You can have both conventional or trunked systems in the personality file.
Took me awhile to get used to that when I started working with Harris radios after years of working on Motorola radios.
hou30guy
Spring tx
And what about, fixed scan,dynamic scan, and enhanced control scan
And last question, when you select a talkgroup and hit the scan button, what is the 3 bars in the right coner, 2 bars,1 bar, nothing, and the S
KC8ONR
bridgeport
Go to the help tap of your rpm software and you can do a search of multiple topics , there you will find alot of help. Its one of the many things I like about RPM software.
