RS Pro 2051 Interference
paramedszaf
Kingston, Pa - Luzerne Co.
Hey Guys/Gals,
Has anyone noticed that this model scanner is super sensitive to interference. I have it side by side with an older model Uniden (BCT-7 maybe?) and what I get as interference on the Pro-2051 just gets scanned thru by the Uniden. Is there a fix for this?
I have tried both with the standard antenna and even hooked the Pro up to a home made discone antenna with no improvment.
Any suggestions would be appreciated.
Thanks,
Ed
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Widely reported, and combined with it's very difficult firmware (which is a mix of GRE and Uniden specs), it's unpopularity doomed it to the circular recycling bin.
There are much better alternatives. Be more specific about your needs. 73 Mike
Bucko
Marietta, Ohio
Actually when I was using my 2051 I found not as bad as my GRE scanners, I live very close to a pager and you soon find out how good the selectivity is on a scanner. A solution would be a notch filter like a PAR but the cost would be half what the 2051 cost new. Then you would need to narrow down the offender that was causing the problem.
