XPR RSSI Indicator on XPR 7550e
AmazingHD
Hello. I've been noticing on my xpr 7550e, the rssi bars does not move, ever, even with a weak signal. I've checked on the xpr 3500e and that rssi bars work fine. Anyone know why or what could be causing the xpr 7550e rssi bars to always show full reception when not the case?
otobmark
NC
Old post but I have same issue. Im worried it will screw up roam and voting scan. I guess I assume that having radio aligned on a fancy service monitor would correct it. Now I wonder..
saksorn013
Thailand
Does your RSSI Bar always show full scale even if the signal is weak?
Check on RSSI by pressing
< 3 times
> 3 times
and see that when you don't get a signal it shows -127 dBm ?
What is the value of the signal shown?
FW R02.09.00.001 is often an unofficial flashed radio from Motorola.
and the tuner is not adjusted properly
It will always show around -75 dBm.
even if there is a weak signal It will still show full scale.
I use translation If you don't understand any point, please inform me.
otobmark
NC
It's a new problem as radio was fine before. Yes, any signal shows full scale. Rssi is skewed towards showing a stronger signal than present but not as far off as the bar scale.
