Note on RTL-SDR Blog Wideband LNA (Bias Tee Powered) listing:About this, I'm assuming it's safe to use the bias-t when using the dipole software that comes with the device, correct? Sorry for the super basic question, but I'm assuming (possibly in error) that it's not a "shorted" antenna like a J-Pole. I think I read somewhere that there could be damaging results if used on the wrong type of antenna.
IMPORTANT ESD NOTE: If you use this LNA placed close to an outdoor antenna, please ensure that your antenna is sufficiently grounded. There is a fast ESD diode, and GDT on the LNA PCB for protection, but if the antenna is not grounded the effectiveness of ESD protection components will be severely reduced, and you run the risk of damaging the LNA.
I'm in a retirement facility on lockdown with an indoor antenna. There is a lot of electronic equipment in this building which makes the noise level very high. I can't even copy CW on HF unless I use a remote SDR.Anything I do now will be an inside job and well hidden from view. Which is why the LNA is so appealing. My main concern is QRM from the PC and all the other electronics I have stuffed in the den.
I use Spectrumspy and an AirSpy R2 also..You have the gain set far too high in SpectrumSpy for it work properly. You are seeing what happens if you overload the Airspy and not the "noise floor".I'm in a retirement facility on lockdown with an indoor antenna. There is a lot of electronic equipment in this building which makes the noise level very high. I can't even copy CW on HF unless I use a remote SDR.
It's even worse on VHF-Low:
Thank you for your comment. I agree with you that properly setting the SDR RF gain is important. I don't agree with you that I have set the RF gain incorrectly. I increase the RF gain until just before the noise floor starts to rise. This gives the correct SNR and is well below the overload point. I use the same technique with the RTL-SDR.COM V3 dongle and SDR#. I was not using a preamp before the SDR. If I had been using a preamp or LNA, it would have been necessary to reduce the R2 RF gain.I use Spectrumspy and an AirSpy R2 also..You have the gain set far too high in SpectrumSpy for it work properly. You are seeing what happens if you overload the Airspy and not the "noise floor".
I have been doing antenna experiments since I was 8; I'm now 88 and still doing them. I have been a ham since the early 1950s and was a radio operator in the US Army in Germany (also a DL4). I have been helping posters with reception problems for the past 12 years on 5 forums with over 10,000 posts. I think I have a pretty good idea of how to adjust an RF gain control.
The method that I use is the method suggested by Paolo Romani IZ1MLL in the SDR# Guide.I am only 68but been into radios since my teens. The issue is what you are calling the "noise floor". In the VHF-LO image, the noise floor is not visible as the gain is set too high for that frequency range. The needed setting to not overload the R2 varies with the frequency range being tuned but you used the same setting for what you posted.
The following adjustment procedure ensures that you get the maximum SNR (*) on what you receive while preserving dynamic range:
• Start with the RF gain set to the minimum level.
• Gradually increase the gain until the noise floor increases by about 5 dB.
• Check that increasing the gain does not also increase the SNR. Then increase the gain one notch higher and so on.
My ambient noise level is much higher than your noise level. The RF gain control on my R2 is set correctly. My location is not the same as your location.I use an R2 also (amoun others) and can tell you I see the same thing if I set the gain where you did for VHF. If I set it much lower, things look as they should. I have other receivers (RSP various models), R9500. R8600 etc. and none of them see that noise.
Did you even look at the video I posted about how I adjusted the RF gain control on my R2?For your 125 MHz 200 MHz BW, set the gain in SpectrumSpy at half the slider level that you did and show me that.
There is nothing wrong with my R2.And something very important, pick up the R2 or slightly wiggle the wires, if you see a change in the "noise floor", the gain is so high, it is causing internal oscillation in the R2. I have seen that using the configuration that you are using.
Yes, that is what it is.Something about this "DC block" was bothering me, then the thought hit me, isn't this simply an inexpensive capacitor enclosed in a fancy RF shielded shell? Kinda spendy (if you ask me) if it's just a capacitive coupler.
My noise level is so high on HF, I can't copy any ham bands with my RSP1A.
Maybe I will try to do a scan during the next power failure.
On the AM broadcast band, most of the stations are wiped out by noise on a battery operated radio:
The dBm scale on most SDRs is only relative, not absolute. The only SDRs that have a calibrated dBm scale are the RSPs by SDRplay.
I see no point in continuing this argument any longer.
I will adjust my R2 to suit the signals at my location; you can adjust your R2 however you want for your location.
I did post two measurements of my noise levels that I made with my signal level meter; perhaps you didn't notice them:I have seen nothing to indicate your noise is higher
This is a video of the VHF scan showing how much the noise varies:I have seen nothing to indicate your noise is higher..... Please set the gain where I suggested and show the screen capture. I might then agree that you have a noise problem.
Thank you for your evaluation and encouraging response.Ok. You do have a noise problem. (On the one figure, in scrolling the screen, I think I missed some of the bar graph labels.) Your last plot is more what I expected to see.
The whole building is full of RFI sources. For example: IIRC, there are over 30 WiFi access points and many LED lights to conserve energy.Have you tried to located the noise source (LED lights or light dimmers). I expect you have but have not found it.
