I get also error while running the plugin on sdrsharp i use version 1.0.0.1784 (sdr# studio 1.0.0.1784)
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.FileLoadException: Could not load file or assembly 'SDRSharp, Version=1.0.0.1632, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
File name: 'SDRSharp, Version=1.0.0.1632, Culture=neutral, PublicKeyToken=null'
at SDRSharp.Rtl_433.Rtl_433_Processor.NotifyPropertyChangedHandler(Object sender, PropertyChangedEventArgs e)
at System.ComponentModel.PropertyChangedEventHandler.Invoke(Object sender, PropertyChangedEventArgs e)
at SDRSharp.SharpControlProxy.PropertyChangedEventHandler(Object sender, PropertyChangedEventArgs e)
at SDRSharp.MainForm.ResumePropertyNotifications()
at SDRSharp.MainForm.playStopButton_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at Telerik.WinControls.RadControl.OnClick(EventArgs e)
at Telerik.WinControls.UI.RadButtonBase.buttonElement_Click(Object sender, EventArgs e)
at Telerik.WinControls.RadElement.OnClick(EventArgs e)
at Telerik.WinControls.UI.RadButtonItem.OnClick(EventArgs e)
at Telerik.WinControls.UI.RadButtonElement.OnClick(EventArgs e)
at Telerik.WinControls.RadElement.DoClick(EventArgs e)
at Telerik.WinControls.RadElement.RaiseBubbleEvent(RadElement sender, RoutedEventArgs args)
at Telerik.WinControls.RadItem.RaiseBubbleEvent(RadElement sender, RoutedEventArgs args)
at Telerik.WinControls.RadElement.RaiseRoutedEvent(RadElement sender, RoutedEventArgs args)
at Telerik.WinControls.RadElement.DoMouseUp(MouseEventArgs e)
at Telerik.WinControls.ComponentInputBehavior.OnMouseUp(MouseEventArgs e)
at Telerik.WinControls.RadControl.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at Telerik.WinControls.RadControl.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4069.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
SDRSharpMerged
Assembly Version: 1.0.0.1784
Win32 Version: 1.0.0.1784
CodeBase: file:///C:/apps/sdrsharp-x86C/SDRSharp.exe
SDRSharp.Radio
Assembly Version: 0.0.0.0
Win32 Version: 0.0.0.0
CodeBase: file:///C:/apps/sdrsharp-x86C/SDRSharp.Radio.DLL
System
Win32 Version: 4.8.4001.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Win32 Version: 4.8.4042.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.8.3761.0 built by: NET48REL1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Assembly Version: 2020.3.1020.40
Win32 Version: 2020.3.1020.40
CodeBase: file:///C:/apps/sdrsharp-x86C/Telerik.WinControls.UI.DLL
Telerik.WinControls
CodeBase: file:///C:/apps/sdrsharp-x86C/Telerik.WinControls.DLL
SDRSharp.Common
CodeBase: file:///C:/apps/sdrsharp-x86C/SDRSharp.Common.DLL
SDRSharp.PanView
CodeBase: file:///C:/apps/sdrsharp-x86C/SDRSharp.PanView.DLL
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
Win32 Version: 4.8.4110.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Telerik.WinControls.RadDock
CodeBase: file:///C:/apps/sdrsharp-x86C/Telerik.WinControls.RadDock.DLL
TelerikCommon
CodeBase: file:///C:/apps/sdrsharp-x86C/TelerikCommon.DLL
Microsoft.GeneratedCode
Assembly Version: 1.0.0.0
SDRSharp.FrequencyEdit
Win32 Version: 1.0.0.0
CodeBase: file:///C:/apps/sdrsharp-x86C/SDRSharp.FrequencyEdit.DLL
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Data
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
Telerik.WinControls.Themes.FluentDark
CodeBase: file:///C:/apps/sdrsharp-x86C/Telerik.WinControls.Themes.FluentDark.DLL
SDRSharp.Rtl_433
Assembly Version: 1.5.0.0
Win32 Version: 1.5.0.0
CodeBase: file:///C:/apps/sdrsharp-x86C/SDRSharp.Rtl_433.DLL
SDRSharp.DMR
CodeBase: file:///C:/apps/sdrsharp-x86C/SDRSharp.DMR.DLL
SDRSharp.APCO
CodeBase: file:///C:/apps/sdrsharp-x86C/SDRSharp.APCO.DLL
SDRSharp.FrequencyScanner
Assembly Version: 2.2.7.0
Win32 Version: 2.2.7.0
CodeBase: file:///C:/apps/sdrsharp-x86C/SDRSharp.FrequencyScanner.DLL
SDRSharp.CTCSSDecoder
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/apps/sdrsharp-x86C/SDRSharp.CTCSSDecoder.DLL
SDRSharp.DCSDecoder
CodeBase: file:///C:/apps/sdrsharp-x86C/SDRSharp.DCSDecoder.DLL
SDRSharp.CoChannelCanceller
CodeBase: file:///C:/apps/sdrsharp-x86C/SDRSharp.CoChannelCanceller.DLL
SDRSharp.DNR
CodeBase: file:///C:/apps/sdrsharp-x86C/SDRSharp.DNR.DLL
SDRSharp.NoiseBlanker
CodeBase: file:///C:/apps/sdrsharp-x86C/SDRSharp.NoiseBlanker.DLL
SDRSharp.WavRecorder
CodeBase: file:///C:/apps/sdrsharp-x86C/SDRSharp.WavRecorder.DLL
SDRSharp.ZoomFFT
CodeBase: file:///C:/apps/sdrsharp-x86C/SDRSharp.ZoomFFT.DLL
SDRSharp.BandPlan
CodeBase: file:///C:/apps/sdrsharp-x86C/SDRSharp.BandPlan.DLL
SDRSharp.FrequencyManager
CodeBase: file:///C:/apps/sdrsharp-x86C/SDRSharp.FrequencyManager.DLL
SDRSharp.Diagnostics
CodeBase: file:///C:/apps/sdrsharp-x86C/SDRSharp.Diagnostics.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
