Sacramento Valley - City of Roseville TRS
sac-emt
Using the RR database for Placer County, I have tried to program a Uniden BC796D scanner with the Roseville TRS, but to no avail.
Anyone know if this system is up and running? Cannot detect any data channel chatter, either.
Thank you!
sac-emt
I am in the Arden area of Sacramento.
I could not get a connection to any of the data channels. I might try on my handheld.
Thanks.
Did you catch that crazy pursuit that just occurred in the last half hour (SSD, Air1 & Sac PD) that ended up in a single vehicle crash at Gerber & South Watt. Crazy!!!
Sac916
Thanks.
10851 with stolen plates that crashed into 3 cars...then finally into a pole
10851 broken in half ( maybe 3 or 4 chunks actually )
suspect had a shirt that said somehing to the effect of..
" don't ask me about yesterday, i don't remember and it was probably bad "
RolnCode3
Sacramento/Bay Area, CA
I can sometimes pick up Roseville from my apartment in Rancho Cordova. It's usually a weak signal, and correct decoding comes and goes, so sometimes it'll find the CC, but not properly decode it, this I can't hear anything. Other times it comes in OK. Depends on the weather and setup, as I seem to be at the limit for my equipment.
It is definitely an active system though. There's traffic on it.
mkewman
Sacramento County, California
i bet that bolo was followed by a few kerchunks. hahaha
