Same frequency, multiple PL/DPL
ht396jm
NJ
Happy thanksgiving!
On a CDM series radio, I have 1 frequency entered multiple times with various PL/DPL. Each entry is labeled differently. Each entry is in the same zone and scan list. Why is it that when the radio scans, it does not necessarily stop on the personality which it is intended for? Rather, it just stops on any entry with that frequency. It’s almost as if the radio is scamming in CSQ. Why is this?
Thanks in advance.
jaspence
Michigan
It is looking for the frequency, not the PL. When it stops, that would indicate the frequency is in use by a user with a different PL. You would not hear anything because the PL is blocking the audio.
KG4INW
Midlothian, VA
By default, it scans in CSQ but you should be able to go in and tell it to follow PL. It's been a while since I've changed a CDM's scan setting (but should remember since I've only touched several hundred of them!) but there is a drop down menu on the Scan window.
ramal121
Lots and lots of watts
Calif Whine Country
Me too, so I had to go look. It's called PL Scan Type. Set to priority and non priority members to keep PL active on all channels.
KG4INW
Midlothian, VA
That's it! Thanks for confirming my memory. A lot rattling around my head these days but I won't be near a computer with Professional CPS this week.
