Santa Fe talkgroups confirmation please
PJH
I received a lengthy submission from what appears to be an out of area submitter. To me it looks like it was cut/pasted from an online source, but I cannot verify. Can anyone local see if these are valid?
Some of the information in already in the DB, some is not:
48 PD1 Boy Dispatch Law Dispatch
80 PD2 Charles Dispatch 2 Law Dispatch
112 PD3 David Detectives Law talk
144 PD4 Edward SWAT Law tac
176 PD5 Frank NCIC Law Dispatch
208 PD6 George Detectives Talk Law talk
240 PD7 Henry Command Law talk
272 PD8 Ida Animal Control Law talk
304 PD9 John Surveillance Law Tac
336 PD10 King PSAs/Tactical Law Tac
1584 PD All Call BOLO/APB Law Dispatch
1616 FD Alpha Main Dispatch Fire Dispatch
1648 FD Bravo Fires Fire Dispatch
1680 FD Charlie Fires Fire Dispatch
1712 FD Delta Medic to Hospital Hospital
1744 FD Prev Fire Prevention Fire tac
1776 FD Tac 14 Event Tac Fire tac
1792 Admin? Admin Fire talk
1808 Secondary Tac 2nd Tactical Fire tac
1872 FD-PD Interoperability Multi tac
1904 Chiefs? Chiefs Fire talk
1936 FD Tac 12 Event Tac Fire tac
1968 FD Tac 13 Event Tac Fire tac
2000 St1 Page Station 1 paging Fire Dispatch
2032 St3 Page Station 3 paging Fire Dispatch
2064 St4 Page Station 4 paging Fire Dispatch
2096 St7 Page Station 7 paging Fire Dispatch
2128 St8 Page Station 8 paging Fire Dispatch
2160 St10 Page Station 10 paging Fire Dispatch
2192 FD Gen Page General paging Fire Dispatch
2224 FD All Stations Page All Stations paging Fire Dispatch
2256 FD Chief Page Chiefs/Admin paging Fire Dispatch
3248 Airport Airport operations Transportation
3344 Parking enforcement Parking Security
3376 SF Pickup Santa Fe Pickup vans Transportation
3536 SF Ride ParaT 1 Senior services Transportation
3568 SF Ride ParaT 2 Meals/Seniors Transportation
4560 Facilities Facilities Public Works
4592 Telemetry SCADA Data
4880 Water Ops Water operations Public Works
4912 Water Security Water treatment plant/Security Security
5232 Water BDD Wells Buckman Direct Diversion project wells Public Works
5552 Streets Trash/drainage Public Works
5904 Radioshop Radio services Public Works
6224 Parks Snow plowing/road salting Public Works
6576 Wastewater and water? Water management Public Works
6896 Traffic Engineering Traffic Public Works
7246 SF T Bus Ops Santa Fe Trail Bus Ops Transportation
7280 SF T ParaT Santa Fe Trail Paratransit Transportation
7568 Buckman SWM 2 Buckman transfer station Public Works
7600 Buckman SWM 1 Buckman transfer station Public Works
8912 Janitors Janitorial Public Works
65536 System ID System Identification Data
kc5igh
Velarde, New Mexico
Good afternoon, PJH.
The talkgroups in your post match the ones I have already programmed for the Santa Fe TRS in my radios.
Your list contains many talkgroups that I either haven't heard at all or haven't heard often enough to reliably identify who they are.
I'll be in Santa Fe next week, so I'm going to add all your talkgroups to my TRX-1 to see how well they match up to what I actually hear.
Thanks for sharing the info!
-Johnnie
madrabbitt
NM
Those match whats in my radio file. Not that order, not the same alpha tags, the TGID's match.
beerzkool
Scanning the Pajarito Plateau since 1995.
Los Alamos, New Mexico
Looks pretty accurate for fire and police. Although I think fire bravo and Charlie are tac groups, not dispatches from what I have heard living in white rock.
madrabbitt
NM
alpha is paging/response.
bravo and charlie are response
numbered tacs are fireground.
kc5igh
Velarde, New Mexico
Those talkgroups match everything I'd already programmed in my scanners over the years of listening to the Santa Fe TRS. I was also able to use that list to confirm (with a reasonably high level of confidence) the identity of several talkgroups about which I was less certain.
Your list contains several talkgroups I have yet to hear at all, but that could be a simple matter of not being in Santa Fe often enough to have picked them up. The "wildcard" setting in my TRX-1 is receiving a talkgroup that wasn't included in the list, so even if the list came from a very well-informed or "official" source, it might still be a little incomplete.
I wouldn't worry very much about some of the alpha tag details. Over time, many talkgroups in trunked systems and "channels" in conventional systems become used for purposes that can be a little different from what was officially intended.
Without knowing anything at all about your criteria for doing so, I think it may be okay to post your list in the RR database . . .
Hope this helps!
-Johnnie
kc5igh
Velarde, New Mexico
Hello again, PJH.
There may be a typo in the talkgroup list you previously posted.
7248 (not 7246) appears to be the correct number for the Santa Fe Trails Bus dispatch talkgroup. I don't believe I've heard anything coming through on 7246, but I'll keep listening.
Hope this helps.
-Johnnie
PJH
Please take a look at the database. Did a large overhaul and added in geo information to it - that covers the city area and not the entire county.
Please submit any corrections via the submissions tab under the system so I can properly track any changes needed.
Thanks!
