On my Uniden 325P2 after DL all TGID's under the SARA system will not scan.Scanner acts like "Nothing to Scan" but I see them in there. Will this have something to do with the DEC or HEX aplication?
052 | 20 (14) | 020 (14) | Quad Cities Metro Simulcast | Scott, IA | 769.50625c | 770.58125c | 771.05625c | 771.55625c | 771.96875c | 772.43125c | 772.89375c |
052 | 30 (1E) | 030 (1E) | Scott Co Rural Simulcast | Scott, IA | 769.35625c | 769.84375c | 770.78125c | 771.39375c |
So I did not DL to a ZIP file just went from RR to ProScan then uploaded it from ProscanPlease attach your programming file for the SARA system so we can take a look at it. You will need to zip the file to be able to attach it. Click on Attach files and open the zipped file.
You can zip up the database file. Use the File Explorer. Navigate to the folder containg the file then zip it up.So I did not DL to a ZIP file just went from RR to ProScan then uploaded it from Proscan
So I actually deleted scanner of all programs......Then only DL the SARA network still shows nothing to scan....You have two systems named 'SARA Network' One contains the site and the other contains the TGID groups. It's not going to work that way.
You want one system containing the site and groups.
It's an easy fix. Do this:
Drag & Drop (or Copy & Paste) the 'Quad Cities Metr' site to the 2nd system then delete the 1st system
Upload to the scanner and see what happens.
LOL yep well rehearsed in the manual not solving issue.....Scanner not reading TGID's on SARA network....even after deleting other systems starting form scratch....'
Drag & Drop the site to the 2nd system.shows Uploading only this on the SARA network
I got rid of the QC ssytem only using BETTENDORF still shows nothing to scan...I even deleted all positions and systems on scanner....started from scratch using one system only for TGID's still "nothing to Scan" true not an expert on this by any means but I've been using this scanner for soemtime now never had this issue
