Satisfaction In Utility Monitoring?
rkillins
Kitchener, ON
In my younger years, I used to get great satisfaction tuning into SW/HF stations with my Radio Shack DX-390 (look that one up!!). I can only imagine what I would have got from it with investment beyond just it's stock antenna. (I was only in my early teens and Burger King wages didn't cut it). I replaced SW listening with local VHF scanning with a Pro2006, and found greater satisfaction of being able to program and scan known frequencies vs manually tuning a dial for hours hoping to capture a SW signal.
40 years later, and the loss of satisfaction with local scanningt now, I'm wondering if there is still any satisfaction in scouring the SW/HF radio waves again for interesting finds. From what I can recall from SW/HF/MF monitoring is capturing signals was a skill knowing when and where to look with highly refined equipment, frequencies were rarely static, and you couldn't "scan" known frequencies.
How much am I off in my understanding of monitoring these bands (looking specifically for utility stations)? Is it worth getting into, or would I find myself highly disappointed, frustrated and potentially broke pensioner?
Any advice, resources on how to get get (back) into this hobby?
MiCon
Mike
central AZ
I'm going to take a stab at getting flamed here.
I, also, found a lot of enjoyment tuning the SW bands as a teenager/ young adult in the sixties and seventies. There was a lot to listen to, and tuning around was fun because I was always finding something new.
Now, however, it's pretty boring. Technology has ruined the fun of SW exploring. Most international broadcast stations have gone off the air completely, or switched to some kind of streaming, satellite, or Internet service. Maritime activity and aircraft, both military and civilian, are using data transmissions instead of voice, and satellite communications.
You can still tune around and find something, including what I just mentioned, but there's less of it now, and the tedium of tuning and finding very little gets old fast.
Just my two cents worth.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Utility HF encompasses many different interests; digital, voice, Aero, numbers stations, etc. Specifically what are you interested in?
As always the better the antenna, the better the results will be. A SDR is a great way to go. You can't really 'scan' because noise levels are higher on the lower HF frequencies, and most scanning will get tripped by any random noise burst. It can be done but it's a bit iffy.
You want to be part of the Utility DXers Forum (UDXF) which can be found on the groups.io server. This is THE place to be for this kind of monitoring. Many years ago it was known as the Worldwide Utility News (WUN) reflector. It morphed into this and moved to the groups.io platform. They recently release 2 lists of frequencies - one an assimilation of freqs from 2024, the other from December - but you need to be a member to get them. The website which has a link to the groups.io server (note that you have to join groups.io - it's painless and for the most part, spam isn't an issue) is
Mike
rkillins
Kitchener, ON
Get into SDR so you can easily see across large parts of the spectrum, just where the activity is at the time.
Put enough antenna wire (50-100') out the window if you can.
Hi tuihill, thanks for that suggestion. I have been getting into SDR as a substitute for my poorly performing scanner radio locally. I wasn't sure what was needed to get into the lower bands. Can you recommend, in addition to the longwire, and software apps specific to HF monitoring?
rkillins
Kitchener, ON
Mike
Thanks Mike, I have just recently subscribed to UDXF after a bit more reading these forums. It looks to have lots of reading which I suspect will answer a lot of questions. SDR could be a option to experiment without investing in thousands of dollars in specialized equipment, especially if it nets similar results. As far as my interests? I don't know as I've rarely had exposure to any of that to discover what each has to offer.
merlin
DN32su
There is a lot more digital stuff out there, Packrat some of the free decoders there are. My SDR is the Airspy HF discovery+, antenna is a line of wire running across the roof.
Got general coverage HF receive in my Kenwood, and resurecting an AOR-8600mkII
tuihill
Te Pahu, New Zealand
There are lots of cheap SDR dongles out there but I've only used as Airspy HF+ Discovery running SDR++ on an old Macbook. That Airspy model is dedicated to HF frequencies only. Works great for me. Compliments my 25 year old Drake R8B on the desk.
I'm using SDR++ because it is the only app I can find that runs on MacOS. Otherwise I would like to try SDR Sharp (SDR#) which is developed by Airspy and seems to be in wide use. One day, when I get a new Macbook, I will get Parallels on it to check out the other Windows only SDR apps.
Anyway, that's all you need. For HF, it's really all about the antenna but you do need room to string it. Otherwise, an active (amplified) antenna would get you somewhere in a restricted situation, but nothing beats a long wire.
rkillins
Kitchener, ON
I will have to research a long wire. Although most suited for the antenna forum ... I certainly cannot run a single 100' length across the top of my attic (does having it in the attic affect quality of reception?), but can it be doubled up? 50' on way and back? I have close to a 100' span of coax running across my backyard (thanks to the local telecommunications provider). Not caring what they thing, could I attach it to that span? Or would I face interference?
tuihill
The attic is probably fine unless you have a steel roof like me. Making a U shape up there to get as much length as possible would probably be better than short and straight.
If you are game, try hanging the wire from the coax along the span and listen for interference. Won't do any harm if its insulated. Don't directly contact any metal fittings on the cable as the exterior braid will be grounded.
Remember that reception conditions will be constantly variable as to time of day and frequencies. You will need to spend some time testing it properly.
devicelab
Whacker Extraordinaire
Nowhere in WA
Not worth it any longer. Need a lot of $$ and rural real estate to make it worthwhile.
FWIW, you can listen over the internet to SDRs around the world for free.
dlwtrunked
For under $200 with an Airspy HF+ Discovery and 50 ft or so antenna or a You Loop antenna, you can do very well. Whether you find things interesting is subjective.
EAFrizzle
Mash Button. Make Far Talk.
SE de DFW, Cabrón
My first SDR setup was a NooElec rtl-sdr dongle, their little balun to transition from wire to the coax, and a 100' roll of speaker wire fashioned into a close to 200' loop strung through the rafters. If your roof construction will pass RF, this is a great stealth antenna for nosy HOA types.
The only modification I did was to clip the ground in the balun to make the loop 'floating',, and there was a noticeable improvement. The rtl-sdr blog V4 already has an upconverter for HF, and can be had for well under $50 is an even better starter sdr than the NooElec for HF. I have a friend that uses the V4 for SWL and Ham listening with a Wilson 1000 mag mount on a cast iron skillet in his bedroom with fairly good results. The cheap dongles are a great way to experiment while you figure out exactly what you want.
The most important thing to remember about SDR experiments is to have fun!
Fair winds and following seas. Low noise floor and good propagation!
KB2GOM
Rensselaer County New York
I've had some decent success with this: Horizontal Room Loop – The SWLing Post
Perhaps a loop around the perimeter of your attic?
HF1964
Its ok for listeners to say get the latest SDR but just what is there to LISTEN to.
Many chase Russian messages of 5 letter groups, many chase ALE soundings
Some leave there receivers on all night to collect the soundings but is that LISTENING.
Anyone who started listening in the 50s 60s and 70s could actually listen to
Radio communications, Ship to Shore was world wide with interesting messages to listen to not just tones. I used a Creed 7B Teleprinter to print out messages and supply lists as well as the many News Agencies sending news 24 hours a day at 50 Bauds.
Later on when the home computer boom started with a Commodore or Spectrum
I could even copy Interpol messages in plain English. Trouble is shortly after the transmissions became encrypted then went to the birds.
The thing is we had to find the signals, no publications or Internet and no scanning but a feeling of achievement so when I agree with those who say there is nothing left to listen to I say “not what it used to be like for sure”.
Richard
Check
Ferrell's Confidential Frequency List​
World Radio History
dkcorlfla
Orlando
I did not see any mention of the SDRplay line of SDRs. I have have the RSP1A and use it with the Connect software (available for Windows, Linux and Mac).
I'm running the Linux version and was quite impressed with the reception on the AM broadcast. The screen shot shows the strong local AM stations and the much weaker station I was able to receive clearly. I was using a stealth flagpole antenna that not even close to being tuned for the lower stuff. I'm sure with a proper antenna it would work even better.
HF1964
I sold my radios years ago, got back into radio a few years later and personally I do not find enough interest to purchase anything so now and then I use WEBSDR which has many WEB Receivers all over the world and it can decode many signals. (worth a look).
I can't recommend any software as I know nothing about Linux but for windows I recommend Sorcerer Decoder
It's free to download and run, its called abandoned software
It decodes everything from RTTY, FAX MILALE,FEEC, STANAG and lots more.
A long wire is fine but you will need a ATU (Aerial tuning unit) so it can be tuned to the frequency you are listening to.
Or to put it another way to match the antenna to the frequency you are tuned to.
Attached image is WebSDR scanning the COTHEN Frequencies
Regards Richard
HF1964
Richard
Check
World Radio History
cherubim
Sydney, Australia
You don't need fancy receivers for utility listening. I do some of my main listening on a Sangean ATS-909W (original) connected to a QRP vertical antenna mounted outside my window and it gives great results. There is still a surprising amount of voice traffic out their if you're into utility monitoring but of course it requires patience and knowledge of signal propagation to get the good catches.
KB2GOM
Are there particular frequency ranges where you hunt for voice signals?
