Scan List
phoboss1
TX
i was thinking of redoing my scan list setup.
Can some of you post on how you have yours setup.
Scan List ... for ex.
scan list 1: SO/PD
scan list 2: Fire/EMS
ect......
thanks for your help.
- Pho
kendrik578
Live Audio Administrator
Greensboro, NC
Scan list 1-Fire
Scan List 2-Police
Scan List 3-EMS
Scan List 4-other
Scan List 5-Sheriff
Scan List 6-VIPER
I think i need to make a scan list with all tac chan.and all dispatch chan.I currently have all releated dispatch and tac in same scan list
Puyallup,Pierce County, Wa.
Here's my list, as I travel all I have to do is push a number.
Scan List 1- Puyallup
Scan List 2- Sumner
Scan List 3- Kent
Scan List 4- Auburn
Scan List 5- Federal Way
Scan List 6- Renton
Scan List 7- Tacoma
Scan List 8- Fife
Scan List 9- Milton
Scan List 0- Edgewood
dracer777
South Dacono, CO
1-S.O.
2-Fire
3-Greeley PD
4-EMS
5-Denver PD
6-Denver FD
7-Larimer PD
8-Larimer FD
9-2-Way Radios
10-CSP
11-CB Radios
13-Broomfield PD
14-Boulder PD
15-Statewide Emergency Response
Also, I have all TACs and appropriate Dispatch channels grouped. Usually if I plan on intently listening to a certain talkgroup, I'll just manually go to it, so as to not miss a word. Since I usually only care about dispatch for GPD when I am listening for more than entertainment purposes, this method makes it easy on me....
phoboss1
TX
ThX
Thank You all for your posts... this is allot of help.
Keep up the posts.
Giant420
Port Hueneme, CA
I live in the land of "banks" with my Pro-97, but I have:
0 - Home (Oxnard PD, Oxnard FD)
1 - CHP
2 - Work (VNC FD, VNC SO)
3 - Misc (Mall security, etc)
4 - Aircraft (PT Mugu, local approach etc)
Thats all I have programmed so far..
kf4sek
Cocoa, FL
I live in a multi-site county and have the VFolder 1 scan lists setup as the following...
1 - Brevard County North Tower (Includes all active TGs for SO, local PDs, and local FDs)
2 - Brevard County Central Tower (Includes all active TGs for SO, local PDs, and local FDs)
3 - Brevard County South Tower A(Includes all active TGs for SO, local PDs, and local FDs)
4 - Brevard County South Tower B (Includes all active TGs for SO, local PDs, and local FDs)
5 - Kennedy Space Center P25/Moto System (In ID Search mode)
6 - Cape Canaveral Air Force Station P25/Moto System (In ID Search mode)
7 - Florida Power & Light North Tower (EDACS Narrowband)(In ID Search mode)
8 - Florida Power & Light Central Tower (EDACS Narrowband)(In ID Search mode)
9 - Amateur Radio, GMRS, and local train frequencies
VFolder 2 is....
1 - Orange County Primary Tower (ID Search mode)
2 - Seminole County Primary Tower (ID Search Mode)
DaWeav
Lemoore, CA
Wow, being new to all this amateur scanning stuff, I keep 'reprogramming' and 'reprogramming' and 'reprogramming'. I'll hopefully get it just the way I want it :roll: someday!
On my PRO-106 all county listings include sheriff/police/fire/EMS which include re-tagged objects for local CHP channels for that specific county from the statewide CHP scanlist.
I know this may seem crazy, but I also keep my channel object numbers in a specific order instead of just chaotic numbering. This works for me since most of my counties have less than 100 channels per county. For instance, I reassign the object numbers so that I know object number 00102 is channel two on scanlist one, because I reassign the channel object numbers so that objects 00100-00199 are on scanlist one, objects 00200-00299 are on scanlist two and so on until the maximum which is on scanlist 018xx. This also lets me know instantly what county I'm listening to without waiting for the alpha tag to display it since county one is all objects on 001xx and county two is all objects on 002xx and so on.
My brother started me doing the LED thing so that I can tell what category the scanner stopped on by having a BLUE LED for Police/Sheriff, RED LED for Fire, GREEN LED for Air, PURPLE LED for EMS, and WHITE Flashing LED for CHP.
I also re-tag channels for different category types from all of the county scanlist into various category specific scanlist. For example, I re-tag all Fire objects in all the scanlist to be on scanlist 12 for instance. So, when I just want to listen to Fire, I select scanlist 12. I do the same thing for Police/Sheriff, EMS, AIR, and all trunk objects so that I can simply listen to the specific category.
Then there is a scanlist I use just for 'testing' which includes things like SRCH and SWPR objects which unleash the power of the PRO106! :twisted:
