While still a great radio, Your 651 scanner won't do P25 PH2, something your gonna need/want in the future.
If money isn't an issue go with the most future proof models currently available, able to deal with the popular simulcast systems [LSM] that are so troublesome to decode in modern times (in a scanner)
the top of the line...
SDS100 handheld
SDS200 base/mobile model
the midgrade (not so good for simulcast systems, but can work)
BCD436HP handheld
BCD536HP base/mobile
the entry level Unidens (don't have full DB built in/compatible, not so good for simulcast systems, but can work)
the above mentioned BCD325P2 handheld
BCD996P2 base/mobile
And the various Whistler models too.
Before you buy anything.. I'd do some homework and do a search though this forums' threads for the known issues that can become apparent with specific models, which after purchase folks bring back/report here the problems that come up, buy what you can afford, but be aware...
Here's a link from a similar thread/question that was asked.. some good links in it to follow..
Hello all.....new to this forum. Our local PD (Bozeman, MT), moved to an 800mhz trunked system a while back. It seems its time for a new scanner. I assume a P25 capable scanner would work? Recommendations? Also, I dont know much about trunked systems, but radio reference lists a system ID...
forums.radioreference.com
