ASAD
Currently 3 cables run into my shack from vertical antennas. Two cables are Andrew Heliax - those connectors inside the shack are grounded. According to instructions, I turned the coax at about 4" diameter right underneath the antenna. A radio is connected to one of those cables and does not have problems in rain or thunderstorms.
For the scanner Discone I am using LMR-400 and is not grounded. The same connector sparks in the rain. Good thing scanner was not connected. What are the reasons for the sparks? Does it have to do with grounding, or choke filter at base of antenna (giving the cable a 4" turn)? Should I install lightening arrestor on all 3 cables?
I would appreciate your help.
