Scanner frequency changes when I enter it.
Bourbon
Hoping somebody can help me out with this.. Programming my scanner, I run into this problem hardly ever. 3-4 times I have entered a scanner frequency, and when I hit enter, that frequency changes. For instance, I enter 151.49750, yet, it stores 151.5000. Why is this? Why won't it let me change it?
Thanks for any info..
Whiskey3JMC
_/|\_Surf's up, Happy DX!
Simulcastylvania, TE
Welcome to the forums. First off, you need to tell us what make & model scanner so we can tell you how to change step size
iMONITOR
Silent Key
S.E. Michigan
151.5000 is most likely the correct frequency, 151.49750 is SO close to 151.5000 it shouldn't make any difference in reception. In fact I don't think151.49750 is correct to begin with. Where did you get it from?
GTR8000
NY/NJ Database Guy
BEE00
It absolutely is a valid frequency. Why not take a few seconds to research it before posting?
Bourbon
Thank you.. I was afraid you were going to say that :). It's just an old BC60xlt-1. Looking through the manual I couldn't find a way to change the step size.. I remember years ago someone saying on a forum somewhere, to program in a frequency that would land on the correct one in a thread for someone else. I never seen the outcome of that.
wtp
Port Charlotte FL
Frequency Range:
29.0–29.7 MHz 10 Meter Amateur Band
29.7–50 MHz VHF Low Band
50–54 MHz 6 Meter Amateur Band
137–144 MHz Military Land Mobile
144–148 MHz 2 Meter Amateur Band
148–174 MHz VHF High Band
Above bands in 5 kHz steps
406–420 MHz Federal Government
420–450 MHz 70 cm Amateur Band
450–470 MHz UHF Standard Band
470–512 MHz UHF “T” Band
Above bands in 12.5 kHz steps
it says step size and nothing about changing it. you got that right.
and that is from unidens site
iMONITOR
Silent Key
S.E. Michigan
151.5 isn't a valid allocation in the US. 151.49, 151.4975, 151.505 are.
GROOM LAKE BORDER SENSORS 151.5 MHz :alien: :whistle::censored::ROFLMAO:
From the site:
"Later generation transmitters were available in three different bands,
Lowband 600 channel system:
The lowest frequency, designated channel 0, is 138.025MHz. The channels are 25kHz apart. The highest frequency, designated channel 600, is 153.0MHz.
The Groom system used to be on 151.5MHz, which would correspond to channel 540.
Midband 1600 channel system:
The lowest frequency, designated channel 0, is 154.005MHz. The channels are 5kHz apart. The highest frequency, designated channel 1600, is 162MHz.
Highband 1920 channel system:
The lowest frequency, designated channel 0, is 162.00625MHz. The channels are 6.25KHz apart. The highest frequency, designated channel 1920, is 174MHz."
Bourbon
From the site:
This is interesting.. :) I'm just not sure how to apply everything else to what I'm looking for. It would be a bummer to have to wait an be abducted.
iMONITOR
Silent Key
S.E. Michigan
Yes, I have tried it both ways. Zero, no zero. Same result.
You don't hear anything on 151.500 Mhz? If there is a signal on 151.4975 try what wtp suggested, they should all work.
wtp post #14
151.49
151.495
151.5
those are the choices.
Bourbon
wtp post #14
151.49
151.495
151.5
Sounds good. I'll program all 3 in and see if I get a hit. I guess if I do, I'll narrow to the one with the best reception. Sure is weird though. Like a glitch. Kinda like side band or something.
iMONITOR
Silent Key
S.E. Michigan
That slightly off frequency thing is very common on scanners.
