hiegtx- If "mscir" doesn't need a Bearcat SDS200 which is NOT good on analog, he's much better off with a Uniden Bearcat BCD996P2 and that scanner is a PROVEN WINNER, and the P25 Digital Squelch Threshold can be adjusted for simulcasting and also depending upon his location in between towers.
It should be know that NOT everyone NEEDS/WANTS to spend $699.95 for a base scanner with a "fancy" color screen with INFLATION meaning food costs/rents/auto insurance so high. And also, the Bearcat BCD536HP has a horrible display screen as I have had that along with the handheld BCD436HP too.
Bob,
I was not “recommending” the SDS200, only pointing out that programming it is essentially the same as the 536HP that he mentions. At the time that was posted, the OP’s location was not noted, so I did not specifically recommend any particular scanner.
Thanks very much for a very detailed reply. I also received suggestion to go with the BCD996P2 which looks like it has the same digital and trunking, no wifi costs less. I'm researching that as well. If you can comment on that model I'd be very happy to hear your opinion.
Looking at your county, Santa Cruz, it appears that public safety in your county is using conventional channels, not a trunked system. So, simulcast is not an issue, and the 996P2 would easily handle what is showing on the county database page. If the database page is correct, (no significant changes that have not been submitted to the database), encryption does not appear to be in use at this time.
I don’t own the 996P2, but do have it’s handheld sibling the 325P2. The P2 series scanners work well, and have been reliable performers for a number of areas.
I would note that the 996P2, unlike the 536HP, is not a database scanner, so it will have to be specially programmed instead of letting the scanner mostly use an installed database to control what is being scanned. For this scanner, you can use FreeSCAN, ProScan, or ARC-XT. While FreeSCAN will handle programming, that software is no longer supported by its original author. FreeSCAN cannot correctly program DMR systems, and has zero support for NXDN. There is a business related DMR system in your county, and Univ of California/Santa Cruz does show as using a NXDN System, though there are no identified talkgroups listed. If neither of these systems interest you, FreeSCAN is all you need.
ProScan and ARC-XT are both paid software programs. While both have a free trial period, after that trial expires, you would need to purchase a license to continue using the program.
ProScan, which is what I use, is $50. That’s a one time fee, and you get free updates as they become available. ProScan includes logging of activity, and also supports a large number of other Uniden scanners.
ARC-XT Basic is for programming the scanner only, and is about $40. If you also want the logging capability, (included at no additional fee in ProScan), you would need to choose the “Pro” version of ARC-XT, which costs about $70. ARC-XT also includes free software updates when and if available.
Programming using any of these three programs is much easier if you become a Premium Subscriber to RadioReference. That allows you to import whatever you want from the database into the software, then use that to program the scanner.
Once you select and order a scanner, you might request that this thread be moved to the California forum. There, you might find someone familiar with your area, and who might be able to provide a programming file to get you up and running quickly, as you get acquainted with your new scanner and it’s capabilities.To request that move, click on the “Report” link in the lower left hand corner of your post, then use that to request that a moderator move this thread for you.
