Scanner Tales: Fire Tone Outs
N9JIG
Sheriff
Moderator
Far NW Valley
“Fire Tone Outs” is a generic term for those multi-tone signals often used by Fire/EMS (and others) to page out responses. These could be used to alert fire stations, personnel or both depending on the agency. While there are several different technologies that have been used over the years the most common over the last few decades has been “Two Tone”. This means there are two sequential tones, followed by a voice message. Sometimes there would be a long third tone used as an alert beep as some radios did not have an internal beep, they would just open the squelch when the proper tones were decoded. This tech was used by several companies back in the day with names like Motorola, Reach, GE, Bell & Howell, Federal and, most famously, Plectron. While Motorola eventually won out, Plectron was the industry leader for years and was synonymous with volunteer firefighters from the 60’s thru the turn of the century. Even to this day, decades after Plectron closed its doors, the name is revered among firefighters, radio hobbyists and historians.
For the most part each manufacturer used a similar format, a steady tone lasting a few seconds followed quickly by another tone of a couple seconds. While the timings were sometimes different the underlying technology was pretty much the same. There was also a “Group Call” function that would set all the receivers with the same first tone (called the “A” tone or second tone (“B” tone”), this was sometimes called “Long A” or “Long B”, and used to open multiple stations or groups with a single tone rather than multiple sets of two-tones.
Originally mechanical devices were used to generate and decode the tones. These included struck devices sized to provide a specific tone, much like how a tuning fork works. They were then amplified and sent to the transmitter using devices much like an electric guitar pickup or even a microphone.
Some receivers used reeds that would vibrate upon application of the received tone and complete a circuit if the correct tone was heard. This method was used by Motorola using “Vibrasponders”. Plectrons usually used tuned coils instead of reeds.
Motorola had used a different protocol, in which two tones were superimposed for the first portion and another two tones superimposed for the second. This was the original “QuickCall”, sometimes referred to as “2 + 2”. Later they sold a simpler system with a single tone followed by another single tone they called QuickCall 2 (“QC2 or “1 + 1”). This was the same tech used by their competitors and is what is still used by countless fire departments to this day. If you listen to the tones used by the TV show “Emergency” it is the original Quick Call 2 + 2 that is used for the Station 51 tones.
Before the BC396T and BCD996T came out in 2004 scanner hobbyists would use surplus Plectron, Motorola or other brand alert receivers or pagers, set to the frequencies and codes used locally. One could also buy tone decoders and install them in scanners or receivers to accomplish this goal. The trick was however getting the tone code frequencies.
Before the Uniden’s came out, I had several Plectron alert receivers of a couple models. One I bought already set up on the regional Fire Mutual Aid system called MABAS. One of the CARMA members I knew would set up surplus “Pageboy” pocket pagers, usually for the same MABAS codes. I also had a couple surplus Motorola and Plectron radios on the channels used at work. They were great radios, even if you did not use the paging function. Wallace Radio would sell you a refurbished Plectron set up with the frequencies and tones you wanted or retune your radio to suit. As far as I know Bob Wallace is still in business and is the EXPERT on Plectrons. See WallaceRadio, LLC.
Speaking of Plectrons, they were made in a little town in Nebraska called Overton, along US-30 near Lexington. Their factory was pretty much the only industry in town aside from the grain elevator and was on Plectron Street. When the company closed some of its people moved over to another company in nearby Lexington, now known as Veetronix, as far as I know there are still making alert receivers built on a Uniden BC350 chassis.
When I was a firefighter, I had one of the ubiquitous Minitor pagers assigned to me and was able to obtain some of the old Plectrons, rescued from the trash. They still worked fine and even the batteries worked. Before that, when I was in school still, my dad had a couple Plectrons from the town we lived in, one for fire calls and another tuned to the police channel.
After the BCD396T and BCD996T came out in 2004 I started to get really interested in Fire Tone Outs. About the same time, we were installing a new console for the 9-1-1 Center at work and one of the components was alert paging for the Fire Department. I had to figure out the codes needed for our town and all our neighbors we relied upon for mutual aid. Most had no idea what the tones were, all they had were the “Cap Codes”. These codes were derived from a group and code within that group so one needed a chart to figure it out. I got a copy of the CentraCom console manual (CentraComs were used by several of the other agencies in the area). That had a decent chart for deciphering these codes.
There was a good reason Motorola made it so difficult to figure these out. In the old days with mechanical reeds there was a limit to the number of reeds available, so they were sold in groups. Each group had reeds with specific tones that would not be resonate with each other. This carried over to electronically generated tones, while this eliminated the technical limitation on the codes used limiting the groups was a way to generate more income from those agencies that needed more than a single Group.
Our new console system from ModuCom had no such limitations, one just programmed in the actual tones needed to accomplish the goal, regardless of the manufacturer of the alert receivers. Some of our partners had Plectron gear (like us), others were all Motorola, some had Federal. There was even some agencies used DTMF (Touch-tone) paging.
For a couple weeks I studied the tone charts and was fascinated with it and was eventually able to figure out the codes used by all the departments in the area. I was then able to program them all into the new consoles. Concurrently I was looking for a way to decipher this stuff over the air. I tried to buy a Midian decoder that was offered at the time, but they would never respond to any inquiries. They had terrible customer support back then and would hang up on me when I called to ask about the product advertised on their website. It was a decoder that would decode and display the tones over the air, and I suspect it was never actually developed for sale.
I then was told about a program called Audition by Adobe and a similar program called Audacity that was open source. I tried both but preferred Audition so bought it. I paired that with the fabulous ScannerRecorder software. I would set up a scanner on a fire frequency and record it with ScannerRecorder for a time, this could be over a few days or even a month. I would then open the resulting recordings with Audition and view the waveforms. Two Tone transmissions were easy to spot visually, and you would just click on the tone’s waveform and the software would display the tone. I got so good at this that I could view a waveform and know it was one I saw and measured before. I could even tell what transmitter they were using as some had characteristic artifacts that would fingerprint them.
Pretty soon I had figured out all the known tones used within the range of my scanners at home, so I brought a radio and a laptop to work and connect the radio to the antenna at the top of the tower and let ScannerRecorder do its thing. I then was able to decode fire tones from a 4-state area.
Now this method had a limitation. The software would indicate the tone but there was enough tolerance, usually a few percentage points, so that determining the exact tone transmitted was sometimes difficult. For instance, 615.8 Hz. Is a common Plectron tone while 617.4 is a common Motorola one. If the tone measured was 616.2 for example, was it the Plectron or Motorola one? For scanners it usually didn’t matter as the tolerances were wide but for work purposes it had to be more exact as that could be a life-safety issue. I then developed a chart of the common tones, color coded by manufacturer. By looking at both tones I could usually figure out at least one of the tone’s origins, and then extrapolate the other’s true code. There was also the timings to look at, different companies systems used slightly different timings for the first and second tones and the spacing between them.
While this was effective it was not absolute. As newer consoles and encoder systems were developed that get away from the limitations in the tones it was common to see tones from different manufacture’s preferred tone sets mixed together. As a Plectron agency we tended to use integer tones like 1200/1400 Hz. while our neighbor used Motorola codes like 979.9/651.9. Later one of the departments needed new tones as they were getting opened by a distant agency on the same freqs that had the same tones, so we switched them to a mixed Plectron/Reach code as we liked the way they sounded together. We really wanted to use the Station 51 tones, but they were QC-1 and we needed to stay with the format. (Yes, we were that vain…)
After all this I wrote an article on how to find and decode fire tones for the CARMA Newsletter and then was approached by Monitoring Times to write an article for them. This ended up being the cover article for the August 2006 edition.
Here in the Phoenix area where I live now the use of Two-Tone paging is very limited, calls at the main airport (Sky Harbor) occasionally use it and a few more rural agencies use it as well. Back in the suburban Chicago area Two-Tone was almost universally used but is much less so these days with trunking systems and other tech being used. It had been fun figuring out the codes, but Uniden took all that fun away when they introduced the ability to search for fire tone out codes directly on the radio, it was then too easy to be fun anymore!
wx9svr
Selective Calling (SELCAL) is a very closely-related 2+2 system. It's used to contact a specific aircraft in flight. Although two aircraft could have the same SELCAL code, there are procedures to avoid/clear up confusion. In an airliner cockpit, the SELCAL code is usually placarded with/near the aircraft's registration (tail number).
There are now 32 valid characters:
ABCDEFGHJKLMPQRS (16 original)
TUVWXYZ123456789 (16 expansion)
In each pair, the first character must be "smaller" than the second. For example, in the first pic above,
GP-CS is valid; however PG-CS & GP-SC would be invalid. Also, a character may only be used once per code (i.e. AA-BC and AB-AC would not be valid.)
The twelve QC tones map to SELCAL tones by the following table:
"Emergency!" Station 51 had QC tones of LP-HK, which would be SELCAL tones of KP-GJ
(Courtesy: Police Interceptor.Com )
mark40
Pike County, Pennsylvania
The Plectron certainly was a great receiver. I lived in a theft prone area in the 80's. After an attempted break in to grab a scanner, acquired and mounted a Plectron under the seat of my vehicle to monitor the county FD dispatch and it served very well. When I moved the the next county north, purchased a used Plectron to continue to monitor the dispatch, and coupled with an outdoor antenna it was just like I was still in county.
When I joined my hometown fire co. in 1976 was issued a Plectron with tubes. And I remember a tuning fork at the fd base station as a young lad.
Eng74
Kern County, CA
I purchased the 330T when it was released for the Fire Tone Ot feature. The only problem was ii could not get it to work with the 2+2 system my county fire used at the time. The county was in the process of switching from UHF to VHF and we got a new quick call system that it works great on. The only problem is the number of tone outs you can have in the 330/396/996/15 family of radios. Ten stations can cover some of battalions in my county. The **36/SDS have more but that is a lot of money to use just for a tone out radio. I was lucky, one of Battalion Chiefs was involved with the radio system change and upgrade so I was able to get the list of the tone out pairs for the entire department.
N9JIG
Sheriff
Moderator
Far NW Valley
I had some success using the 396 and BCT15 on a couple QC 2+2 tone sets but it was kind of hit or miss. There was only a couple that still used it in driving range back then so I only had a couple chances to try it.
If the tones are well coordinated, by having the same "A" or "B" tones you could get away with having a single FTO channel set with the other tone set to zero. While it won't tell you the individual user it would at least open on any tone set with that common tone.
IC-R20
LoBand Nation
Trying to decode two tone pages with my BCT15x was indeed frustrating. It had too much deviation but then someone on here told me I could just use a chromatic tuner for music and that worked perfectly. I connected a voice recorder to the bct15x and left it running throughout the day then imported the recording to audacity which let me find the tone outs quickly with the audio graph and played them while holding tuner to speaker.
I found if I had multiple tones programmed I could often end up missing a specific tone out as it tried to cycle through them so I just have them hold on a specific unit I’m interested in following. It’s an odd set up where I live where most units have their own individual tones except for 2 small remote fire stations which both have a tone for their own house. I imagine it’s nice for the firefighters sleeping since they don‘t get woken up for other units pages.
IC-R20
LoBand Nation
View attachment 166459 View attachment 166460
I’ve heard the bing bong selcalls on some maritime HF too as well as the rare commercial land mobile HF users.
N9JIG
Sheriff
Moderator
Far NW Valley
Before the Narrowbanding mandate I found that by using NFM I was able to get more reliable tone activations and on Tone Out Search the displayed tones were more accurate. After they went narrowband it remained more accurate than before. That said, I would not rely on a scanner for mission-critical use like station alerting. We did replace a failed station alert receiver for a weekend with one of my scanners but made sure that if they did not acknowledge quickly to use one of the alternate alerting methods.
I did run into a situation on our local fire channel where I needed more than 10 sets of tone outs. As they were multiple agencies and all self-dispatched they had no common tones and there was no coordination of the tones other than everyone having everyone else's tones for direct calling of automatic aid companies. My solution was multiple BCT15's, one each for the departments I wanted to monitor. Eventually I had 12 BCT15's and 15X's, using 8 or 9 for tone outs for various channels with 3 or 4 on the local one.
mws72
Quad-Cities (IA-IL) USA
I did the same thing with recording fire channels and looking at the tones. In fact it lead to my greatest non-eSkip or F Layer reception. I caught an ambulance a fire frequency direct. It was north of Green Bay WI and I live in Davenport IA. That is a long distance and I didn't hear anything else that night I figured out through a weather map it was a very thin duct along a cold front moving through the upper Midwest.
MiCon
Mike
central AZ
They weren't used for just paging or tone-outs. I was a volunteer fire fighter in NJ during the 1960's. The first tone (high) was used to open the alert receivers each fire fighter had. The second tone (lower) immediately followed the first, and activated the roof top sirens at the fire stations.
INDY72
Indianapolis, IN
I so remember driving my family crazy first with my scanner and the tone drops, then as an volee with my actual pager as it was even better volume wise when **Deee, Dooo... dahhhh, Weeeee. Crystal Springs volunteers, Crystal Springs volunteers, 10-70 J3, xxxx so and so street. 10-70 J3, xxxx so and so street. Please respond. First page, xxxx hours.** LOL especially at like 2 am!
Eng74
Kern County, CA
We had the red brick Motorola one channel Minitor pager. The big white base charger that had a spot for two extra batteries. They would wake the house up for sure better than when we went to the alpha numerical pagers.
INDY72
Indianapolis, IN
Ours were black with a yellow band taped on it. Four channels with 1 being our town fd, 2 being County eoc, the other 2 were neighbors eoc just fir awareness as we helped them a lot! Chief had three pagers for all the vfds. Wish unications were around back then!
One13Truck
My home 20 eating pizza.
I started in the early/mod 90’s putting an Olympus recorder next to the scanner. At one point it was the VN-4100 and later I updated to the DS-30. I’d record until it was full then go through the files and replay what I wanted to save to record onto the computer. I did this at home and when traveling. Unfortunately 98% of everything I had back then is either lost after not making transitions to new computers or so poor audio quality it’s not worth having.
I wish I had more saved from back then. Until the mid 90’s my county was a mix of county dispatch, regional centers, local dispatch centers, and self dispatched departments. Most of the tone sets carried over when everyone was forced (UGH) onto the County 911 center. I wish I had more audio saved from those days when things ran better. If only I could take a time machine and my SDS100/200 back to grab recordings to save them like I was able to do a year ago during the transition from conventional to P-25 which is now saved on a stored away micro SD card.
