stantorres
What scanners and ham radio's (mobiles) can be vehicle mounted and will turn on when I start the car without me having to manually press the power button?
I also haven't had any SD card corruption resulting from the power wire being on an ignition switched circuit. I just have to remember if I make any changes such as avoids, Quick Keys, etc., I have to cycle power with the On/Off switch so those changes are written to the SD card.
This is hair-splitting, but there isn't a "surge" when starting a vehicle - surge meaning more power than expected/anticipated. Rather, this is a "voltage drop" situation where so much of the battery's power is going to crank the motor. The 536 scanner doesn't like it when voltage drops, so it cycles power.
Newer Ford trucks have a big issue with this as the motor turns off for fuel economy when stopped at traffic lights, etc. There are posts on work-arounds for this issue.
Getting back to original question, I've had the following models of Uniden scanners in a mobile application where the power wire was connected to an ignition switched circuit: 536, 996XT, 996T, 796D and 780.
I suggest consideration be given to an amplified speaker when scanners are in mobile use as well as GPS devices.
