Scanning DTR/DLR
Ilikeradiostuff
Shelby county, Alabama
I would like to scan the businesses around me that use DLR/DTR radios, as I hate not being able to listen. Which radio in the series would be best to use to discover and scan? Any advice from someone who has done this before? TIA
a417
I would recommend a scanner, as trying to discover using a consumer radio is a bit more tedious and they can be very balky to program.
I do most of my discovery stuff via SDR on a laptop, so there is also that route.
Not sure what your price point is, but the current gold standard is an SDS100...
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
For FHSS radios? Good luck with that.
kruser
Well Known Member
W St Louis Cnty, MO
You won't even detect the DTR/DLR radios with a scanner. They use FHSS in the 902-928 MHz ISM band.
If a business users is using them with the default group codes, you can use another DTR also set to the defaults and hear them.
letarotor
Arlington, TX
I'm trying to remember what DTR and DLR stand for? I did a quick Google search with no luck. And what is FHSS? Can anyone explain please? Thanks...
Brian
COMMSCAN
Reconrider
Inside the Galaxy
Radio Galaxy
And what is FHSS?
Frequency hopping spectrum.
Basically it has defined frequencies
1 = 900.000
2 = 901.000
...etc(NOT LEGIT FREQUENCIES JUST EXAMPLES)
and the radio/software will randomly pick out of the 100s of possible combos for a frequency and spend like 1 second of talk time on that 1 frequency before changing to another one. Scanners can't track that fast. Also not possible to figure out it's next frequency
vagrant
ker-muhj-uhn
California
DLR & DTR are model types of Motorola FHSS ( Frequency Hopping Spread Spectrum ) radios. There are DLR1060 and DLR1020 radios which run at a lower cost than the DTR600 and DTR700 radios.
I have used the DLR1060 as well as the DTR700 models and they work very well, within reason, considering the frequency range they use.
RayAir
Not my YT channel but it's a recording I made 10+ years ago.
This is what a DTR transmission sounds like if you can follow the FH:
I haven't played with these in a while. A few box stores near me use DLRs. Default profile.
PGHSCANNERWACKER1
Pittsburgh pa
here in Pittsburgh at my location i have about 5 different company's in a 5 block area use DTR radio on public channels .. i just bought a dtr radio and scan all the public channels and i got all of the 5 places so i hear what they are saying.. most places around me that uses those radios just buy them turn it on and use them. my old school uses them as well on a public channel. i find most people don't really know much about the extra features on the radios unless they a radio/scanner Wacker like me lol ..
Ilikeradiostuff
Are there channels that can be set up to not be scanned or not able to be listened to? Such as a more private channel then FHSS already is
Reconrider
Inside the Galaxy
Radio Galaxy
So default is like a "key code" and default I think is 0000. If you change that 0000 to something else, unless person plans to try all combos, they can't hear the conversation(s)
sopranosno1
How many public channels does the dlr or dtr have? One day I may have to invest in one for how popular they are getting.
PGHSCANNERWACKER1
Pittsburgh pa
i do believe you can make private channels i would do your research im not great with dtr other then i setup the public channels to scan to see what's out there in my local area
