jonwienke
More Info Coming Soon!
Scan and Search. Just Search TGs. I program my county system twice. Scan on one and Search on the other
If you scan both instances of the system at the same, that is a waste of scan time.
I do it on 2 scanners the same way and my feed runs on ScannerLive. I don't miss anythingIf you scan both instances of the system at the same, that is a waste of scan time.
Wrong.I do it on 2 scanners the same way and my feed runs on ScannerLive. I don't miss anything
Yep, just like when the first Uniden DMA scanners came out and there was a pitiful talkgroups per system limit - "It's fine, just program police and fire as separate systems and scan both of them!" No, that's not fine - your talkgroup limits suck.When you split a trunked system into police and fire and scan both copies, when the scanner is scanning the police copy of the system, all fire traffic is ignored, and vice versa.
DMR is like the 2nd worst thing to hit this hobby, next to 'E'. DMR has basically flooded the bands with heaps of digital noise and no voice calls. Repeaters that sit there and spew out digital nonsense when no one's even talking.
Searching isn't as fun as back in the day cause of all the obnoxious DMR interference. See, back the in day, back inna dhey, use to be, when the scanner stopped on something, it was an actual voice call. Now, 90% of it DMR digital burst garbage and no one actually keyed up and talking. So you search around and most of what the scanner stops on is trash.
Perhaps scanners need an option to natively disregard these digital control channels.But then you'd have to lock out almost everything.
A SDR is way faster than a scanner for searching. You can search spectrum at 10MHz/s with a cheap RTL-SDR, and even faster with more expensive ones.
In many cases they are difficult to use as they have not enough sensitivity and overloads easily and have a lot of interferencies. When you receive a signal you can never be sure of if its actually transmitted on that frequency. You can use a dongle SDR receiver but really need to run the result in a conventional scanner set to record the audio.Absolutely! I'm surprised more people aren't using SDR's for searching!
/Ubbe
Not true. If you manually change the tuned frequency, the signal will move in the opposite direction of an actual signal if it's an image.In many cases they are difficult to use as they have not enough sensitivity and overloads easily and have a lot of interferencies. When you receive a signal you can never be sure of if its actually transmitted on that frequency.
