HP-1: SD Card file error
fishinfrank8
It tells me to remove the batteries and power for one minute to reset and if this does not work then go to Sentinel all clear to reset. When I do this I get this error message: Data base is corrupt, operation is cancelled. I also get a message that tells me something is wrong with my SD card. I have tried everything to fix the problem, any suggestions?
fxdscon
¯\_(ツ)_/¯
Follow the directions here:
http://forums.radioreference.com/un.../312803-home-patrol-2-tilted.html#post2385475
fishinfrank8
---------This is the message that I get when I try to clear data on the home patrol unit. I did reload Sentinel as you suggested and followed your directions.------------------
HomePatrol Sentinel
Database is corrupt.
Operation is canceled.
Could not find a part of the path 'F:\HomePatrol\favorites_lists\favorites_lists\favorites_lists\favorites_lists\favorites_lists\favorites_lists\favorites_lists\favorites_lists\favorites_lists\favorites_lists\favorites_lists\favorites_lists\favorites_lists\favorites_lists\favorites_lists\favorites_lists'.
OK
fxdscon
¯\_(ツ)_/¯
HomePatrol Sentinel
OK
That message would be indicating an error on your computer rather than the scanner. Seems that the path to the database file has been corrupted.
fishinfrank8
I have tried removing the program several times and reloading. Always comes up with the same message
