osros
Hey,
Just broke out the old gear getting ready to setup a shack again. I have a couple of issues with my SDR-14 setup and looking for other users of the unit or help from anyone.
Firstly I had this setup back in the day when the SDR-14 was still avail and all seem to work fine so I'm not sure if i have a hardware issues or a SW issue, here is what I got
AOR A5000A +3, SDR-14 is the setup and here is how its performing. I had a list of what worked and what did not worked but after a final test here are my results and looks like SW.
SpectraVue = Works with SDR14 as standalone HF, Works with radio control, A5000A + SDR14 on IF 10.7mhz output on HF and above as spectrum analyzer.
SDR Radio/Console = Works with SDR14 as standalone HF, With A5000A + SDR14 on IF 10.7mhz output seems deaf on HF and all freqs. to expand on this when used with external radio control the connection creates a popping noise on the radio and effects the signal on screen.
WinRad 1.6 = Cannot get this SW to work with SDR14 would start and stop immediately when SDR is selected. It does work is soundcard mode. This used to work if i recall.
Since SpectraVue seems to work all around I'm guessing the hardware and IF output is good. SDR Radio is frustrating me being what seems to go deaf I can get it to hear but only if I key up a radio can see it on screen but anything else further/weaker has no effect even a strong NOAA signal nothing. Am I trying to use SDR Radio the wrong way since it seems to only work ok directly with the SDR in HF?
Basically that's it I like to use the external radio control and SDR14 in a HF & VHF/UHF to see spectrum using one SW package. I could swear this used to work with SDR Radio but now SpectaVue is my only option, I like the features of SDR Radio and really want to use that or similar.
Any help appreciated.
EDIT/UPDATE
I just tried HDSDR which looks alot like Winrad but better. Anyway HDSDR is acting just like SDR Radio with the popping when radio control is used, and deaf, something is just trashing it. Only common factor I can see is the use of OmniRig for radio control. Spectravue does not use it and earlier versions of all this SW if I recall did not use it either. I wonder if there is something there. Anyone has similar results?
EDIT/UPDATE
