SDR# automatic plugin update not working
mancow
N.E. Kansas
I have been using the automatic update script created by the Russian guy. It would go out, update sdr sharp abd then install all his plugins such as the fast scanner that opens the separate window. Recently when running the batch file it opens the command line box and says sdrsharp not located hit any key, then it closes. No matter where I place the file the result is the same. So, I installed most manually but the fast scanner doesn't work. It didn't show up in the list. I noticed the download fir that plugin doesn't have a magic line entry included which I assume is the cause of it not showing up.
