This my first adventure! Just got a NooElec R820t SDR. With their help I downloaded and installed Zadig and SDR Sharp software. Not sure what the hell I'm doing/ All I get is static. Tried FM local stations and NOAA. Nothing.
And it goes without saying but I'll say it anyway since new people happen upon the wonders of SDR all the time, especially with RTL-sticks from NooElec:
The included antenna is - for the most part - useless for any decent signal reception save for stuff in the 800 MHz or higher range (again, for the most part). Yes it can "pick up" some stuff at lower frequencies; FM radio typically is easy to get primarily because the signals are so powerful to begin with so even that craptastic antenna gets something it can work with.
But your first order of business now should be to get yourself a far more capable antenna, which will mean more than likely you'll need to get a pigtail (MCX connector on one end to attach it to the RTL stick itself and BNC/TNC/SMA/whatever on the other end to attach to an actual antenna). The cable on the included antenna is as low quality as you can get and still actually work, but it too is a piece of crap so I wouldn't bother trying to splice it to something useful, you'll just end up losing more signal than you already area.
After that - meaning getting a decent antenna of some kind, even one you make yourself from coat hangers or electrical wire (seriously) - the sky's the limit with SDR.
"Welcome to the party, pal..."![]()
All these are good answers and I would like to add some steps.
For SDR# and RTL devices.
After loading the program
Right of the "Play" button is a white box default is "Other(Sound Card)" It is a drop down box, click the down arrow press RTL/USB.
Press Play after you see 000.105.500 appear.
Press Configure. A new window pops up. I recommend selecting RTL AGC
Press Offset Tuning
Press OK
You must calibrate your receiver.
In the Radio section select NFM
Tune to a NOAA weather radio frequency for your area.
Looking at the spectrum analyzer you will see a peak in activity either to the left of the needle or almost to the middle or to the right. You must center the peak of the activity on top of the needle. Here is how to complete this:
Press Configure
You will see ppm correction.
If peak is to the left of the needle go up in ppm correction until the very peak of the activity centers on the needle. If its to the right of the neddle you have to go down in ppm correction. after centered press ok.
Take note ALL RTL2832U R820T tuners have a 28.8khz local oscillator. EACH one is different there is no standard ppm correction. I have 3. One is +58ppm(nano) Number two is +43ppm(mini) Number 3 is +63ppm(mini). Do not use my numbers they will not be right for you. Best to let it heat up 3 minutes then set ppm.
For FM Broadcast
Left side first section says Radio
Select WFM
Select FM Stereo
Select CorrectIQ
Tune you favorite station. If the station has RDS you will see information appear in the box on top right. That is the Spectrum Analyzer with the big red tuning line. (Ya gotta love Youseff's sense of dial type radios with the red needle from the old days)
Max msps without loss is 2.44msps
Understanding how to tune frequencies in SDR# and other software defined radios for newbies.
The frequency display show 12 digits. First 3 digits are gigahertz. Second set of digits is in megahertz. Third set of digits are in kilohertz. Fourth set of digits are in hertz. For FM brodast you want to focus on the Second and third sets of digits. Tune around in 100 khz increments for FM broadcast. Kilohertz the third set of digits.
Example
100.5 fm The KATT
You should see
000.100.500.000 You can use your mouse wheel on each digit or click on each digit.
You can tune another way.
Two boxes in SDR#. Top is spectrum analyzer bottom is water fall. Just clicking on the peaks in the spectrum analyzer tunes to that station. Same as the waterfall. Click on the center of that red area also tunes to that frequency. If set to 2.44msps You will see only 2.44 mhz of frequency but not limited as it will keep tuning and tuning until you reach the limit of the dongle. 24mhz-1.766ghz.
This is just to help you get started.
Any suggestions where I may buy these parts? Thanks!
Great find Manny. A thin square or circle of sheet metal makes a good portable ground plane also.
Ground Plane
Here is a better illustration on this:
100.500mhz
100 megahertz point 500 kilohertz
Gigahertz(ghz)= one billion cycles per second
Megahertz(mhz)= one million cycles per second
Kilohertz(khz)= one thousand cycles per second
Hertz(hz) is 1 cycle per second.
A frequency of 1.5ghz will look like this in SDR#
001.500.000.000
A frequency of 100.5 mhz will look like this in SDR#
000.100.500.000
A frequency of 100khz will look like this in SDR#
000.000.100.000
A frequency of 100hz will look like this is SDR#
000.000.000.100
Did you finally tune in some radio stations in SDR#???
Press Offset Tuning
Press OK
Press Configure
For FM Broadcast
Select WFM
Select FM Stereo
Select CorrectIQ
Example
100.5 fm The KATT
You should see
If this is the one You ordered then You should have it by the weekend.Thanks for this..was trying to figure out where to start on the yahoo sdr# group site. I just ordered my NooElec from amazon. Is there any other advise or reading while waiting ? Does anyone know if this is shipped from china as the 10 $ dongle takes 6-8 weeks ? Thanks again, Rich
Sold by NooElec and Fulfilled by Amazon.
