- Joined
- Dec 16, 2024
- Messages
- 12
I am doing a test to be able to tune into signals in the 850Mhz range.
I am using the dipole antenna that came with my RTL SDR Blog v3 dongle. I have the 2 short elements on, fully collapsed. Using SDRTrunk, I am able to listen to local emergency voice calls. They play fine, and I can see which frequencies are playing by reading the SDRTrunk log files and looking at the waterfall.
Now...I am trying to go into SDR# and listen to them there, one at a time. I see the signals in SDR#, but all i hear is noise. Are there settings I can change in order to tune into and listen to the same signals as I am getting in SDRTrunk. If I can make this work, I think i will learn a lot about SDR#. I don't think the antenna is the issue, since I am seeing peaks in the chart in SDR#, and the same frequencies play just fine in SDRTrunk.
The attached photo shows what I see in SDR#. Again, all i hear is white noise though. I cannot adjust the settings so I can hear the actual voice calls.
Thanks!
Thanks!
