SDR# Locking Up Computer - Windows 10
pinkfish457
Slidell, Louisiana
Two days ago I upgraded to Windows 10 from Windows 7. Now I can't run SDR# for more than a few minutes before the computer locks up. I have to turn the computer off with the on/off button. I deleted the dongle, reinstalled using Zadig no change.
I use HDSDR which runs perfectly. Changing to HDSDR isn't a problem, I like the simpler SDR#.
Any suggestions.
AggieCon
Texas
I would revert while your computer still has the old OS files saved. Windows 7 is substantially better, especially for SDR. I think you've learned the first reason why.
jdolina
Lorain Ohio
Any suggestions.
I had similar issues but am running just fine on multiple windows 10 machines. WHat I did to fix the lock up was to basically create a new instance of SDR# with a clean plugins.xml and .config. When it was stable I started to add things back and have been good with no lockups since.
KD8DVR
Elitist Ham
Columbus, Ohio
Definitely wouldn't revert back to win7. Free upgrade time expires at end of month. Sdr# works fine on win10.
Sent from my LG-D631 using Tapatalk
eorange
♦RF Enabled Member♦
Cleveland, OH
Exactly...used to run SDR# quite a bit on Windows 10 with zero problems. In fact I've run 5 different SDR software packages on Win10 and never had a stability issue. Do what jdolina said.
