SDRPlay SDR play and OP25
philacop
Clifton Hgts PA
Hi
I just got a SDR play DX and want to run OP 25 using it Can I use the SDR play to do this?
I currently run it with a SDR dongle RTL
Thanks!
TeddJohnson
OP25 will happily run using a single RTL dongle but it doesn't need or use SDR Play
Hey @boatbod does that mean it won't work with an SDRPlay RSP1A? I saw a few references in the github issues, but it seemed to indicate it should work?
boatbod
Talbot Co, MD
RSP1A is fine with op25, but you'll need to get the drivers and 'args' specified correctly. Search around a bit here and you should find the magic incantation for the config file.
