SDR REMOTE CONTROL
KB3KBR
(ಠ_ಠ) (◣_◢) (。◕‿◕。)
Oil City, Venango County, PA
Does anyone know of a way to remotely control an sdr on a Windows machine? I've seen NetRemote but it seems the website is dead for that plugin for SDR#. Any help would be appreciated. Thanks!
PDXh0b0
Woodland, WA
I just tried spyserver, with the blog 4 I could only get it to work above 24 mhz, i didn't check how high it would go "derp"
thewraith2008
The NetRemote plug-in for SDR# is available here via the GitHub repo releases page.
The download is an EXE installer which will install the DLL and update the plugins.xml into SDR# for you.
- This installer may not be suitable for the newer SDR# versions.
I'm guessing this is not what you think it is as it still requires you to make a program that can then connect to the plug-in and issue the JSON commands (as detailed in the GitHub page) that will control SDR#.
dave3825
Suffolk County NY
If your on a windows/Linux machine and the sdr is on another windows machine, Team Viewer, Real VNC etc gain you access to the PC running the sdr.
dave3825
Suffolk County NY
Hmm,, I don't get hounded with Teamviewer. But maybe once a year my activity triggers their AI into thinking I am using commercially and I have to fill out an online form stating I am not, and when they review closer, my access is reinstated. I maintain two family members PC's, my Pi, laptop, all my linux installs and my upstairs PC.
KB3KBR
(ಠ_ಠ) (◣_◢) (。◕‿◕。)
Essentially I'm looking for a Proscan equivalent for SDR. I'll take a look at the suggestions. I do have TeamViewer but they are also hounding me about commercial use just cause I sign in from work to my home computer.
What is spyserver and how does it work?
thewraith2008
For the Spyserver option, you can configure 'spyserver.config' (using notepad) so it doesn't list/announce the setup as publicly available.
# List Server in Airspy Directory
list_in_directory = 0
