SDR++ Server Help
ArloG
SDR++, Airspy SDR# have server options. Really need help from a seasoned user to help understand how they work.
If I have a SDR radio that is supported in, focusing on SDR++, that works on it and I want to send the I/Q stream to Satdump or other applications that don't support the radio that does work with SDR++. Is it doable?
Or if a radio like one of the RTL chipset varities is used on the server. Does it have to be be the same type on the "client" SDR app.?
Like. I see that my RSP2 is no longer supported with newer SDR# versions. If I were able to use the radio with SDR++.
Could I get SDR# to connect with SDR++ server. Or any other application that can connect to the SDR++ server?
Hope it makes sense. I tried the tutorials and got pretty confused.
dave3825
Suffolk County NY
There is a video here on sdr++ server and setting it up.
Pretty sure for that you would use Network Sink Module which is used to send raw signal to those other applications.
