SDR Trunk Conventional Stream
jeepsandradios
East of the Mississippi
Running into issues with SDR Trunk and streaming. I find mixed information but I was under the impression we can now stream conventional via SDR Trunk. I have 4 channels working in SDR trunk. Can hear on my speaker of the PC but do not seem to make it to the stream. In SDR Trunk Streaming tab I have a enabled feed "Broadcastify Feed" that shows connected. Ive done multiple tests and broadcastify shows it connected but I dont ever hear audio on broadcastify. I did find stuff about alais list and I use an alias list for those frequencies although I only have a few MDC IDs in it. I did select the alias list in SDR as well for the streaming tab. I dont see any streaming check boxes in the individual channels.
I really dont want to waste a scanner for this as my pi crashed a few years ago.
dave3825
Suffolk County NY
It’s it just one freq and works with a tg range, you can probably leave it like that, but if multiple conventional freqs, pretty sure a unique tg for each one would be required.
jeepsandradios
So I lost power yesterday and lost everythign in SDRTRunk. All channels streaming info and all. I set it all back up the way it was but dont seem to get audio on my feed again. I have 2 channels and can hear audio and see audio on the channel. But nothign to stream. Each has its own individual alias with talkgroup range 1-65535. Whe I set this up all worked well once I added the talkgroup range and has been solid until power yesterday. I did add a UPS so it wont drop but can't get any audio accross the stream.
dave3825
Suffolk County NY
Is SDRT receiving the calls? And just not passing audio?
jeepsandradios
Yes SDRT is receiving fine. It appears to have started working randomly overnight as I went to mess with it today and I have audio on the broadcastify. I guess I need to backup folders as well. Iver never lost everythign from SDR trunk on many power changes reboots etc.
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
An RR Stream? An RR calls feed? For conventional, you assign a fake TGID, but they need to start at 1 and go up. If you have four freqs, the TGs I think need to be 1-4. If you look at the commandline window associated with SDRTRunk, it'll likely tell you what is going on. I had a similar issue the other day and the CLI window showed [1 No-Freq-Table-Entry-For-Upload]. That was because my single conventional freq was set with a take TG of 100. I changed it to 1 and it worked fine. Now, I wasn't sending conventional P25 but rather a regular NBFM paging freq. So maybe it works different with P25 conventional, and what I've said may have no bearing. But do check the CLI
