SDRplay API
rbuxton
Hesperus, CO
I'm in a predicament,,, I am using a RSPduo as my SDR. My version of DSD+ Fast Lane needs SDRplay API v3.06 in order to work while my SDRuno software needs v3.09 to work. When I installed API v3.06 in order to run DSD+ it uninstalled API v3.09 so that I cannot run SDRuno. And vice versa, when I install API v3.09 again it uninstalls API v3.06 so that I cannot run DSD+.
I am using DSD+ 2.228 and am unable to unlock the latest version with my previous password. It's been several years since I've used DSD+.
If anyone has a brilliant idea on how I can install both API v3.06 and v3.09 for the different programs please reply.
Thanks.
venom6733
Im actually running API 3.11 and Im able to use the dsdplus with fastlane on my RSP1A & RSPdx but I cant use the older RSP1. I dont have a duo but I would think it would work 3.09 even though the DSDPlus program calls for v3.06. Im using DSD+ 2.395 and it says I need at least API 3.07.
As far as having 2 different API's install on the same computer, I dont think it can be done (as far as I know of)
You could buy one of the RTL-SDR's for like $30 off of amazon and install ZADIG and use the FMP24-CC.bat...just be sure you dont get a cheap clone of the RTL-SDR which I hear isnt worth a whole lot
maus92
Eastern Shore
You can install another copy of Windows on a virtual machine and use the other version of the API. But it's a PITA. Perhaps the developers of DSD will update their program for the current API.
Whiskey3JMC
Simulcastylvania, TE
Don't hold your breath. It's been almost a year since the latest DSDPlus update. Next update (if ever there is one) better be substantial. Fingers crossed this doesn't become abandonware
rbuxton
Hesperus, CO
alrightee then. Sounds like I'll be installing/uninstalling API's when I want to use different programs.
dave3825
Suffolk County NY
Are you a lifetime member or did you pay for 1 year?
rbuxton
Hesperus, CO
It seems that my problem is that I cannot extract the updated DSD+ ZIP file. The DSD+ program will download the latest update (2p395) and when I extract it I need a password and the password I enter on the extraction program is the one I previously used when the updates were sent by email with a link to download. Something changed between 2018 and now where it seem I need a different password. Compounding the problem is that the email address used to received DSD updates is one that I no longer use.
dave3825
Suffolk County NY
Its the same password.
Not sure what your using to unzip but try these that are mentioned in a different thread.
You have to download it, unzip it (with winrar or 7zip) using the password originally sent to you in email, extracting it to your DSDPlus folder and overwriting any older data in there.
I only use 7zip
rbuxton
Hesperus, CO
I only use 7zip
I'm using 7zip. I select the file (DSDPlus2p395.zip) > Extract > Enter password (cut and paste from old email) > OK > goes the extracting process then returns a message "Wrong password: DSDPlus.exe & Notes.txt"
rbuxton
Hesperus, CO
I find this in the Notes.txt file:
DSD+ 2.186
Addressed buzzing audio when monitoring DMR trunk traffic in single receiver mode.
Fixed single receiver mode NEXEDGE96 trunk tracking / voice following.
Added a manual check for updates. Press U in DSD+ to check for a newer version.
When a newer version is available, modify the trailing digits in the download link
in your notification email to match the new update's version number.
Use the same zipfile password to unpack each new update.
So I go to my browser and enter: https://www.dsdplus.com/dsdplusuploads/FastLane/wSvxHpTyus_DSDPlus2p395.zip
and I get this:
This www.dsdplus.com page can’t be found​
dave3825
Suffolk County NY
That's odd. When I do it with the link I received for 2p228 and change to 2p395, it downloads. Are you sure your lifetime?
rbuxton
Hesperus, CO
Also, if I just try to download the file from the link (right click>save linked content. It does not find the file, like it does not exist. Is your link to the file the same as mine (above)??
dave3825
Suffolk County NY
In the version you have now, does it have check for updates in the Misc tab?
Most of the link is the same. I believe the random letters have to do with each specific user.
dave3825
Suffolk County NY
Are you typing your password exactly?
Edit Mine is capitols, lowercase and numbers.
