SDRTrunk SDRTrunk Beta-3 brief or no audio
w8jfj
Central Michigan
My system is a WIN 10 with 32 gb. Have been running Version 0.5.0 Alpha 6 for quite a while, no issues. Just started testing with 0.5.0-beta3 Gradle 7.4.2. The application starts just fine and early on the audio has no issues. After a few minutes I get little to no audio. An occasional blip of audio but now mostly quiet. I see plenty of calls going in the events list. And listening to the P25 system on OP25_Boatboat running on a Pi-4 audio is just fine. I jump back to 0.5.0 Alpha 6 and all is well.
Any suggestions? Thanks, John.
My 0.5.0 beta3 log
WARNING: Using incubator modules: jdk.incubator.vector
14:08:02.375 INFO i.g.d.icon.IconModel - loading icons file [C:\Users\John\SDRTrunk\settings\icons.xml] [11MB/512MB 2%]
14:08:02.375 INFO i.g.d.icon.IconModel - Icons file not found at [C:\Users\John\SDRTrunk\settings\icons.xml] [11MB/512MB 2%]
14:08:02.745 INFO i.g.d.log.ApplicationLog - Application Log File: C:\Users\John\SDRTrunk\logs\sdrtrunk_app.log [18MB/512MB 3%]
14:08:02.791 INFO i.g.d.log.ApplicationLog - SDRTrunk Version : 0.5.0-beta3 [20MB/512MB 4%]
14:08:02.791 INFO i.g.d.log.ApplicationLog - Gradle Version : Gradle 7.4.2 [20MB/512MB 4%]
14:08:02.791 INFO i.g.d.log.ApplicationLog - Build Timestamp : 2022-05-04T14:55:06.134-0400 [20MB/512MB 4%]
14:08:02.796 INFO i.g.d.log.ApplicationLog - Build-JDK : 18.0.1 (BellSoft 18.0.1+12 [20MB/512MB 4%]
14:08:02.796 INFO i.g.d.log.ApplicationLog - Build OS : Linux (amd64 5.13.0-40-generic [20MB/512MB 4%]
14:08:02.796 INFO i.g.d.log.ApplicationLog - [20MB/512MB 4%]
14:08:02.796 INFO i.g.d.log.ApplicationLog - ******************************************************************* [20MB/512MB 4%]
14:08:02.796 INFO i.g.d.log.ApplicationLog - **** sdrtrunk: a trunked radio and digital decoding application *** [20MB/512MB 4%]
14:08:02.796 INFO i.g.d.log.ApplicationLog - **** website: GitHub - DSheirer/sdrtrunk: A cross-platform java application for decoding, monitoring, recording and streaming trunked mobile and related radio protocols using Software Defined Radios (SDR). Website: *** [20MB/512MB 4%]
14:08:02.796 INFO i.g.d.log.ApplicationLog - Memory Logging Format: [Used/Allocated PercentUsed%] [20MB/512MB 4%]
14:08:02.796 INFO i.g.d.log.ApplicationLog - Host OS Name: Windows 10 [20MB/512MB 4%]
14:08:02.796 INFO i.g.d.log.ApplicationLog - Host OS Arch: amd64 [20MB/512MB 4%]
14:08:02.796 INFO i.g.d.log.ApplicationLog - Host OS Version: 10.0 [20MB/512MB 4%]
14:08:02.796 INFO i.g.d.log.ApplicationLog - Host CPU Cores: 6 [20MB/512MB 4%]
14:08:02.796 INFO i.g.d.log.ApplicationLog - Host Max Java Memory: 7 GB [20MB/512MB 4%]
14:08:02.796 INFO i.g.d.log.ApplicationLog - Storage Directories: [20MB/512MB 4%]
14:08:02.796 INFO i.g.d.log.ApplicationLog - Application Root: C:\Users\John\SDRTrunk [20MB/512MB 4%]
14:08:02.796 INFO i.g.d.log.ApplicationLog - Application Log: C:\Users\John\SDRTrunk\logs [20MB/512MB 4%]
14:08:02.796 INFO i.g.d.log.ApplicationLog - Event Log: C:\Users\John\SDRTrunk\event_logs [20MB/512MB 4%]
14:08:02.796 INFO i.g.d.log.ApplicationLog - Playlist: C:\Users\John\SDRTrunk\playlist [20MB/512MB 4%]
14:08:02.796 INFO i.g.d.log.ApplicationLog - Recordings: C:\Users\John\SDRTrunk\recordings [20MB/512MB 4%]
14:08:02.806 INFO i.g.d.util.ThreadPool - Application thread pool created SCHEDULED and CACHED executors threads [20MB/512MB 4%]
14:08:02.806 INFO i.g.dsheirer.gui.SDRTrunk - Home path: C:\Users\John\SDRTrunk [20MB/512MB 4%]
14:08:02.806 INFO i.g.d.p.SystemProperties - SystemProperties - loaded [C:\Users\John\SDRTrunk\SDRTrunk.properties] [20MB/512MB 4%]
14:08:02.806 INFO i.g.d.p.SystemProperties - SystemProperties - application properties loaded [C:\Users\John\SDRTrunk\SDRTrunk.properties] [20MB/512MB 4%]
14:08:03.126 INFO i.g.d.s.t.m.TunerManager - Discovering tuners ... [6MB/56MB 11%]
14:08:03.235 INFO i.g.d.s.t.m.TunerManager - LibUsb API Version: 1.0.262 [7MB/56MB 13%]
14:08:03.235 INFO i.g.d.s.t.m.TunerManager - LibUsb Version: 1.0.22.11312 [7MB/56MB 13%]
14:08:03.346 INFO i.g.d.s.t.m.TunerManager - LibUsb - discovered [17] potential usb devices [7MB/56MB 13%]
14:08:03.356 INFO i.g.d.s.t.m.TunerManager - Discovered tuner at USB Bus [3] Port [3] Tuner Class [RTL-2832] [7MB/56MB 13%]
14:08:03.356 INFO i.g.d.s.t.m.TunerManager - Discovered tuner at USB Bus [4] Port [6] Tuner Class [Airspy] [7MB/56MB 13%]
14:08:03.356 INFO i.g.d.s.t.m.TunerManager - Tuner: USB Tuner - RTL-2832 USB Bus:3 Port:3 - Added / Starting ... [7MB/56MB 14%]
14:08:04.776 INFO i.g.d.d.f.c.ComplexPolyphaseChannelizerM2 - Sample Rate [2400000.0] providing [96] channels at [25000.0] Hz each [10MB/56MB 19%]
14:08:04.790 INFO i.g.d.s.t.m.TunerManager - Tuner: USB Tuner - RTL-2832 USB Bus:3 Port:3 - Applying Tuner Configuration [10MB/56MB 19%]
14:08:05.061 INFO i.g.d.s.t.m.TunerManager - Tuner: USB Tuner - Airspy USB Bus:4 Port:6 - Added / Disabled [11MB/56MB 19%]
14:08:05.061 INFO i.g.d.s.t.m.TunerManager - LibUsb Hotplug event notification Is Not Supported on this platform. [11MB/56MB 19%]
14:08:05.072 INFO i.g.d.s.SettingsManager - SettingsManager - loading settings file [C:\Users\John\SDRTrunk\settings\settings.xml] [11MB/56MB 19%]
14:08:05.499 WARN i.g.d.v.VectorUtilities - CPU supports maximum SIMD instructions of Species[float, 4, S_128_BIT] [27MB/56MB 48%]
14:08:06.327 INFO i.g.d.p.PlaylistManager - Loading playlist [C:\Users\John\SDRTrunk\playlist\saved playlist ver 3.xml] [18MB/56MB 33%]
14:08:07.285 INFO i.g.dsheirer.gui.SDRTrunk - starting main application gui [58MB/284MB 20%]
14:08:07.555 INFO i.g.d.a.b.AudioStreamingBroadcaster - [sdrtrunk] status: Connected [66MB/284MB 23%]
14:08:12.991 INFO i.g.d.c.c.ChannelAutoStartFrame - Starting [1] channels now - user invoked [55MB/284MB 19%]
14:08:13.259 INFO i.g.d.a.c.m.JmbeAudioModule - Loading JMBE library from [C:\Users\John\SDRTrunk\jmbe\jmbe-1.0.9.jar] [66MB/284MB 23%]
14:08:13.271 INFO i.g.d.a.c.m.JmbeAudioModule - JMBE audio conversion library loaded: JMBE Audio Conversion Library v1.0.9 [66MB/284MB 23%]
14:08:13.272 INFO i.g.d.a.c.m.ImbeAudioModule - JMBE audio conversion library IMBE CODEC successfully loaded - P25-1 audio will be available [66MB/284MB 23%]
14:08:13.306 INFO i.g.d.d.f.c.ComplexPolyphaseChannelizerM2 - Sample Rate [2400000.0] providing [96] channels at [25000.0] Hz each [69MB/284MB 24%]
w8jfj
Central Michigan
I run into it, showing its receiving but nothing coming through audio only on p25 conventional though everything else seems to work. You might get a faster response posting on the google group sdrtrunk - Google Groups
Dave, thanks for the reminder. I have so many forums and groups open my brain was thinking this was the SDRTRUNK on Google (that is where I intended to post it). I'm glad it's Friday. Have a great weekend.
SpectralContent
Baltimore, MD
I am experiencing the same issue on my end with the Baltimore City Simulcast P25I system. When the program starts, it works great. However, after a few minutes of decoding it starts to get random audio blips and eventually the spectrum acts as if there is some increase in power/interference and makes the P25 coding nearly unintelligible until it finally stops decoding anything. I went back to Beta2 and it is running with no issues.
I also noticed that the menu option to select a preferred tuner in the system menu only showed one of my two RTL-SDRs.
maus92
The OP
Windows or Linux / Mac? I've been running a Linux Beta 3 box on the state's P25P2 system 24/7 since release with no issues. Airspy Mini is the radio.
Chronic
I cant even get it to run on win 10 . starts up once , then when i try to add a radio it crashes and will not open again .
SpectralContent
Baltimore, MD
Windows 10 Pro on a dedicated Lenovo ThinkCentre. Ive looked at AirSpy but haven't pulled the trigger to buy to date.
