sdrtrunk custom icons
golsonnj
Savannah, GA and East Hampton, NY
I am looking to see if there are any SDRTrunk custom icons that others have shared. Specifically looking for ones representative of helicopters, lifeguards, hospital, and emergency management agency. Thanks.
dave3825
Suffolk County NY
golsonnj
Thanks. I'll give that a try. Kind of thought I might be able to just use generic icons off the internet but wanted to see if anyone already had some that they might have uploaded somewhere.
rjdj2000
Gone Cuckoo
Central NY
To add to the whole custom icons, I have found, mainly of FB, the insignia of a fire department, car of police agencies, badges etc. Run them through a free online background remover and set background as transparent. Saved them all to a particular folder then went in the icon manager, set them all up. Went back into alias list and put corresponding icon with talkgroups/alias. Once you get the hang of it, it works quite well.
golsonnj
Thanks everyone. Knew how to add a custom icon, just wasn't sure if there were any out there that others found useful. I ended up finding a number of image files that just needed to be converted/saved in a .png file format to be able to be imported to SDRTrunk as custom icons. Ended up with about 3 different helicopter icons, a hospital icon, an emergency management agency icon, a couple lifeguard themed icons and a marine patrol one that pretty much cover the gap I had in default icons.
RobDLG
USA
I was annoyed that the SDRTrunk documentation didn't include recommended dimensions for custom icons.
Then I remembered that those 1990s Java Archive (JAR) files are just ZIP files! I figured I could use the built-in icons, which are stored in the images directory in lib/sdr-trunk-0.6.1.jar, for reference.
ImageMagick's identify command revealed that I was operating on a false premise. There is no single pair of height/width numbers for the included icons.
Bash:
acars.png PNG 32x16 32x16+0+0 8-bit sRGB 498B 0.000u 0:00.000
action.png PNG 32x32 32x32+0+0 8-bit sRGB 522B 0.000u 0:00.000
ais.png PNG 32x16 32x16+0+0 8-bit sRGB 495B 0.000u 0:00.000
ambulance.png PNG 48x28 48x28+0+0 8-bit sRGB 3188B 0.000u 0:00.000
am.png PNG 32x16 32x16+0+0 8-bit sRGB 456B 0.000u 0:00.000
aprs.png PNG 32x16 32x16+0+0 8-bit sRGB 504B 0.000u 0:00.000
audio_muted.png PNG 256x256 256x256+0+0 8-bit sRGB 2772B 0.000u 0:00.000
audio_unmuted.png PNG 256x256 256x256+0+0 8-bit sRGB 6987B 0.000u 0:00.000
broadcastify.png PNG 181x180 181x180+0+0 8-bit sRGB 31499B 0.000u 0:00.000
concrete_block_truck.png PNG 48x36 48x36+0+0 8-bit sRGB 2611B 0.000u 0:00.000
control_play.png PNG 16x16 16x16+0+0 8-bit sRGB 592B 0.000u 0:00.000
control_stop.png PNG 16x16 16x16+0+0 8-bit Grayscale Gray 403B 0.000u 0:00.000
Curve-fitted-background.png PNG 135x135 135x135+0+0 8-bit sRGB 24754B 0.000u 0:00.000
Curve-fitted-chart-background.png PNG 616x235 616x235+0+0 8-bit sRGB 91654B 0.000u 0:00.000
Curve-fitted-graph-gridlines.png PNG 20x20 20x20+0+0 8-bit sRGB 152B 0.000u 0:00.000
cwid.png PNG 32x16 32x16+0+0 8-bit sRGB 654B 0.000u 0:00.000
dispatcher.png PNG 48x48 48x48+0+0 8-bit sRGB 5619B 0.000u 0:00.000
dmr.png PNG 32x16 32x16+0+0 8-bit sRGB 520B 0.000u 0:00.000
dump_truck_red.png PNG 48x34 48x34+0+0 8-bit sRGB 3519B 0.000u 0:00.000
fire_truck.png PNG 275x183 275x183+0+0 8-bit sRGB 75595B 0.000u 0:00.000
fm.png PNG 32x16 32x16+0+0 8-bit sRGB 378B 0.000u 0:00.000
garbage_truck.png PNG 48x33 48x33+0+0 8-bit sRGB 2614B 0.000u 0:00.000
icecast.png PNG 160x160 160x160+0+0 8-bit sRGB 33318B 0.000u 0:00.000
loader.png PNG 48x34 48x34+0+0 8-bit sRGB 3177B 0.000u 0:00.000
loading.png PNG 50x50 50x50+0+0 8-bit sRGB 3318B 0.000u 0:00.000
ltr_net.png PNG 32x16 32x16+0+0 8-bit sRGB 413B 0.000u 0:00.000
ltr.png PNG 32x16 32x16+0+0 8-bit sRGB 379B 0.000u 0:00.000
motorola_type_2.png PNG 32x16 32x16+0+0 8-bit sRGB 405B 0.000u 0:00.000
mpt1327.png PNG 32x16 32x16+0+0 8-bit sRGB 435B 0.000u 0:00.000
no_icon.png PNG 16x16 16x16+0+0 8-bit sRGB 743B 0.000u 0:00.000
no_record.png PNG 172x172 172x172+0+0 8-bit sRGB 5832B 0.000u 0:00.000
nxdn.png PNG 32x16 32x16+0+0 8-bit sRGB 470B 0.000u 0:00.000
openmhz.png PNG 512x512 512x512+0+0 8-bit sRGB 15497B 0.000u 0:00.000
opt_bus.png PNG 42x27 42x27+0+0 8-bit sRGB 2986B 0.000u 0:00.000
p25_1.png PNG 32x16 32x16+0+0 8-bit sRGB 493B 0.000u 0:00.000
p25_2.png PNG 32x16 32x16+0+0 8-bit sRGB 462B 0.000u 0:00.000
passport.png PNG 32x16 32x16+0+0 8-bit sRGB 443B 0.000u 0:00.000
police.png PNG 48x25 48x25+0+0 8-bit sRGB 3556B 0.000u 0:00.000
propane_truck.png PNG 48x30 48x30+0+0 8-bit sRGB 2534B 0.000u 0:00.000
rdioscanner.png PNG 152x152 152x152+0+0 8-bit sRGB 4053B 0.000u 0:00.000
rescue_truck.png PNG 329x153 329x153+0+0 8-bit sRGB 75823B 0.000u 0:00.000
school_bus.png PNG 48x30 48x30+0+0 8-bit sRGB 3865B 0.000u 0:00.000
shoutcast.png PNG 136x136 136x136+0+0 8-bit sRGB 28226B 0.000u 0:00.000
site.png PNG 32x16 32x16+0+0 8-bit sRGB 460B 0.000u 0:00.000
system.png PNG 32x16 32x16+0+0 8-bit sRGB 644B 0.000u 0:00.000
taxi.png PNG 292x170 292x170+0+0 8-bit sRGB 70414B 0.000u 0:00.000
train.png PNG 48x36 48x36+0+0 8-bit sRGB 3017B 0.000u 0:00.000
van.png PNG 48x19 48x19+0+0 8-bit sRGB 2048B 0.000u 0:00.000
waypoint_white.png PNG 20x34 20x34+0+0 8-bit sRGB 3435B 0.000u 0:00.000
rjdj2000
Gone Cuckoo
Central NY
On the images I've used, I never resized them to anything. Just took what I got and put it in. Any of them you'll never read what is in there, if there is any txt in it but from the shape and colors, I know what it is. I mainly did it so I could match alias name to an actual FD/PD emblem if I was able to get them. I managed to scour FB with all of my local FD to get their insignia for their departments. Did the same pretty much for the local law around me and so far everything has worked out just fine. On the latest nightly, in dark mode, I see where one of my icons did not get the transparent background but while I like the dark mode, I didn't like that there were no grid lines anymore so I've went back to 0.6.1.
