SDS100/SDS200: SDS-100 boot screen
djeplett
NE Wisconsin
There. I attached my screen as a TXT document. Download it and rename the extension to BMP and you should be good to go.
@Avguy1 Put the file (named "opening.bmp") under the "BCDx36HP" folder on the SD card. It doesn't appear for very long on boot up.
  • opening.TXT
noaim
Milwaukee, WI
Thank you!!
Sent from my iPhone using Tapatalk Pro
teknishun
Alvin, Texas
You can upload your own image?
Sent from my iPad using Tapatalk Pro
Yes. You could probably even put your own ugly mug (i.e. your face) on it for identification purposes. Helps to prove that
it is yours if it ever gets stolen and you are trying to get it back.
W4KRR
Coconut Creek
Is that all there is to it; dropping an "opening.bmp" file into the SD card's "BCDx36HP" folder? I tried this and it doesn't work. I used one of the files uploaded by one of the members here.
djeplett
NE Wisconsin
That should do it. It has to be the correct size & bit depth, too. It doesn't appear for very long. Maybe 1 to 1.5 seconds on mine.
Badboy536
i dropped the file in after renaming it. but nothing has changed on the start screen.
W4KRR
Coconut Creek
djeplett, I used the file you attached in post #21 above; I just changed the extension to .bmp. I'll have to do some tinkering to see if I can find out why it isn't working for me.
Badboy536
i cant get it to work either
Hans13
Are you able to load it in a graphics program such as paint? That will verify that you properly downloaded the file and correctly changed the extension.
(If someone is having trouble properly renaming the extension to BMP, right click on the file and use "Open with" to load it into paint and save it out as a proper BMP file.)
W4KRR
Coconut Creek
Does the length and width pixels size matter? Is BMP the correct format? Cause I still can't get it to work for me.
fxdscon
¯\_(ツ)_/¯
As pointed out in several posts in this thread, yes. It must be the same size, the same format, the exact same name and case, and located in the same location on the card as the original.
W4KRR
Coconut Creek
I got it figured out. I was using files uploaded by others here, but the trouble was that once I downloaded them, they weren't the correct size or format, even though I gave them the correct name. The incorrect images were showing a size of around 77 kb. The correct images will show as around 226 kb in size.
I used a freeware program called paint.net to fix them.
So:
240 x 320 pixels in size
.bmp format
24 bit depth
around 226kb finished size
Hans13
So:
.bmp format
24 bit depth
Yep. That's what I was trying to suggest in post #30 to folks having trouble... Load it into a graphics program, fix it, and save it out.
