SDS 100, Does not install to computer
ChuckinSC
Irmo, SC
When I insert the usb cable/micro to the scanner and computer it does not load (show). I do get the "chime" that the connection is made - but the scanner is not seen. Suggestions since I can't use Sentinel until the scanner is recognized?
gcopter1
Winter Park, Florida
Are you using the correct port on the scanner?
Is the one labeled "CHARGE".
I too, made the same mistake, when I first got the SDS100. It didn't seem intuitive but, it's the only enabled port of the scanner as of now.
IAmSixNine
Dallas, TX
Go into the device manager of your windows computer and see if the driver needs to be reloaded.
iMONITOR
Silent Key
S.E. Michigan
Turn the scanner ON then respond to the question, "." for Serial Connection or "E" for Memory Card.
ChuckinSC
Irmo, SC
Thank you. Very unintuitive. Connected to charge and all is well. Thanks again.
