I just got back from a 500 mile road trip each SDS100 connected to its own GPS unit all scanners connected to the same antenna a TRIBAND 150 450 700/800.
This time I took SDS100 #1 and entered all the counties along my route plus 1 county each side and setup Location Control Range 20 Miles.
With SDS #2 I turned on the Full Database Range 20 Miles
Just For Fun I Programmed my TRX-1 the same as SDS100 #1
What I learned SDS100 #1 run circles around SDS100 #2 and the TRX-1 running 6 Counties at a time turning off 3 and turning on 3 every county.
The SDS100 #1 still out worked the TRX-1 with was a hand full adding and removing Favorites running down the road.
As for SDS #1 and SDS #2 the SDS100 #2 did not keep up with SDS100 #1 due to all the BLOAT in the DATABASE. I setup SDS100 #1 with each County Law Fire and EMS only and that is the way to go. I will be running all 3 in the same configuration here at local for a few weeks in my service van as I was happy with what I learned on the road trip.
