I know there's a lot of discussion in other threads on the SDS-100 battery but I didn't think any of it focused on a possible workaround for the fact that the radio will not record without the battery pack.
Has anyone looked into what would need to be provided from a battery pack substitute to bypass/fool the feature that protects the SD card. I don't want to power the radio from the hack-pack just trick it into thinking it has a battery while on USB power.
More specifically I'm wondering about a simple, small, non recharging battery that puts enough juice into the radio to fool it into thinking it has a regular battery pack installed. I suppose it'd need protection against charging (although I guess if you always remembered to use the non charging USB connector this could be skipped).
My one battery pack did the swell thing while traveling last month and I wanted to at least keep the case/connector pieces but being on the road I didn't feel that I could safely fool with the swollen battery. Perhaps when the second one goes I'll cannibalize it for a hack attempt.
Has anyone tried something like this or pondered it enough to rule it out.
Thanks in advance.
Thanks in advance.
