I_am_Alpha1
- Joined
- May 21, 2014
- Messages
- 268
Has anyone done it yet? I got the dreaded swollen battery after two-years of ownership. It's the big battery. Amazon has the cheapest replacement that I've found...nearly $50. Last year I did allot of work on 18650 harvesting and pack building, so I thought I'd give this a try since individual batteries can be had for cheap. Since the pack was so swollen, some of the glue had already separated. Only glue and tape are holding it together. Inside there are three pouch batteries connected to a BMS (1S3P). The BMS wires to the outer case are very short, not leaving much working room...and they are covered with glue on both ends. Two of the three batteries are spot welded...the center one is soldered to the BMS. Replacing them would be an easy task. Flush cutters made removing them easy. I opened a pouch out of curiosity...nothing but the material rolled up. I searched the number on the battery and only found the MSDS from the manufacturer. Good thing I read it--"Do not swallow batteries". Whew, that was close...I was feeling peckish and thought a Lithium battery would make a good snack . I've not found a replacement battery that would make doing this economical. Measurements inside the case are about 55mm x 32mm x 25mm. My batteries are swollen so the measurements may be off a bit...32x50x9--with the tabs on the 32 side. If the 08/18 on the battery is the birth date, it was nearly two years old when I got it. I searched the manufacturer's website and didn't find this battery--they have one with a little less mAh and one with a little more...didn't find anything when searching those part numbers. If anyone finds a replacement battery, please post the info...I've only found ones that would make the cost of replacement the same as buying a new one from Amazon.
